VAG
Old Feb 1, 2007 | 07:31 PM
stephenson27's Avatar
Default RE: VAG
Yes to the laptop unless you buy a really long cable or park right next to your desktop. From what I've seen with VAG, no it's not that difficult.
Old Feb 1, 2007 | 10:10 PM
cincyTT's Avatar
I'm make believe
Default RE: VAG
ORIGINAL: stephenson27
Ok, so you're saying to get vagcom and get a base line. Then use limmi to tweak it and each time I modify it create new graphs and compare to the original. If using a boost controler (manual) do I need to get a fuel pressure regulator to compensate or will limmi cover it?
Pretty much, but im not sure what your plans are for the mbc and fpr. Please elaborate further.
Old Feb 2, 2007 | 02:01 AM
Default RE: VAG
Well, I'm planning to chip it, install a boost controler, and a DV. Other than that I'm just going to stick with what I've done so far and when it's time for my timing then I'm thinking about either the APR stage 3 or putting together a stronger kit. I don't see that happening any time soon though.
Old Feb 2, 2007 | 02:04 AM
cincyTT's Avatar
I'm make believe
Default RE: VAG
chip + water/meth injection + lemminwinks = a good time
Old Feb 2, 2007 | 11:58 AM
diehlryan's Avatar
Default RE: VAG
^^ thread jackers
Old Feb 2, 2007 | 12:14 PM
Default RE: VAG
Hey now, we're still talking about Vag and limmewinks and laptops and options when using them.
Old Feb 2, 2007 | 12:25 PM
diehlryan's Avatar
Default RE: VAG
in that case.. continue.
