Vag-com coding for window roll and 1 touch lock/unlock
Old Oct 17, 2007 | 09:33 PM
cmh's Avatar
cmh
Default Vag-com coding for window roll and 1 touch lock/unlock
Does anybody have the Vag-com coding info for window roll with key fob and 1 touch lock/unlock? I had it when I did it to my car but lost the link and can't find it via search. I know you add/subtract but I dont remember what blocks and numbers![:@] TIA
Old Oct 17, 2007 | 09:58 PM
225tt's Avatar
Default RE: Vag-com coding for window roll and 1 touch lock/unlock
I am looking for this info also...
Old Oct 17, 2007 | 11:26 PM
cmh's Avatar
cmh
I found some of my info: 15948-064=15884 I think this is for the one touch lock/unlock. I still need the window roll coding.
Old Oct 17, 2007 | 11:30 PM
neur0tic's Avatar
look in the lemmingwinks tuning thread. i think andrew posted a link for it in there. Either that or the w/m install thread.
Old Oct 17, 2007 | 11:45 PM
cmh's Avatar
cmh
Thanks- I found this on Ross-tech's site:
35-Central Locks: -- KWP-1281
VAG-COM Works fine (note: pre-'97 A4's may not have this module).
Recode locking options
[Select]
[35 - Cent. Locks]
[Recode - 07]
Enter the coding below
[Do It!]
Write down the existing coding for future reference.
A4 pre-1998 with Delta radio and anti-theft system
Standard Coding: 03468
A4 pre-1998 with Delta radio, anti-theft system and keyless entry
Standard Coding: 12172
A4 1998+ with Concert/Symphony radio and anti-theft system
Standard Coding: 03340
S4, A4 1998+ with Concert/Symphony radio, anti-theft system and keyless entry
Standard Coding: 16140
Add the following options to your coding number:
+64 Windows up, sunroof close, and windows down with remote.
-04 One touch unlock of all 4 doors and trunk
-1024 Remove horn honk when arming
+32 Auto lock/unlock of doors (Doors lock at 15 mph and unlock when key is removed)
So, if you want to have a 1999 A4 with Concert radio and anti-theft system and keyless entry, and you want to add window control with the remote along with auto-lock, then:
add 03340+64+32= 03436
Add 64 for remote roll up and subtract 4 for the 1 touch feature on the TT.
Old Oct 18, 2007 | 08:50 AM
DurTTy's Avatar
if your goal is to have it set to do one touch roll up, ie after you dsic battery/or reset the ECU.
then you can do it without the VAG. mine works as follows, driverside - press and hold till window rolled all way down(both) and hold for 10 seconds, do same for roll up and hold 10 secs, then repeat one more time rolll down and hold 10 secs , it will set it to do auto roll/up/down one tocuh. you can do th esame from teh outside with the key to roll up or down windows open door hold .. roll down all way , hold key in position for 10 secs, repeat same in opposite directions until the window works as desired
its in the owners manual [8D]... if this is not your intention .. then just [sm=angrymail.gif]
Old Oct 18, 2007 | 08:54 AM
vegastt's Avatar
I found this on AW hope it helps Its under coding control module for coupes/roadster ( for TT's of course).
JUST CLICK
Old Oct 18, 2007 | 10:25 AM
cmh's Avatar
cmh
Thanks durtty but i know about that feature- I can roll my windows up or down with the buttons on my remote (like holding the key in the door only with the lock/unlock buttons instead) and all my doors lock or unlock with one tap on the keyfob rather than once for drivers twice for pass. I am looking for the coding in VAG-COM to turn this stuff on on another TT.
^^^^^vegas that link you posted above doesn't work for me^^^^^^^^^
Old Oct 18, 2007 | 02:34 PM
vegastt's Avatar
Lets see if this one does.
abbra kadabra
If this doesnt work go to AW - resources - tech arcticles - TT coding controll coupe/roadster
Old Oct 19, 2007 | 09:38 PM
achTTung's Avatar
http://www.audiworld.com/tech/elec40.shtml
geez guys, i gotta post this weekly?
