Vag-com coding for window roll and 1 touch lock/unlock
Old Oct 19, 2007 | 11:54 PM
cmh's Avatar
cmh
Default RE: Vag-com coding for window roll and 1 touch lock/unlock
For some reason I suck @ searching- I tried every related term I could think of and still no luck! ps. Durtty=1st w/ link
Old Oct 19, 2007 | 11:55 PM
cmh's Avatar
cmh
dubble
Old Oct 20, 2007 | 07:16 AM
neur0tic's Avatar
ORIGINAL: DurTTy
if your goal is to have it set to do one touch roll up, ie after you dsic battery/or reset the ECU.
then you can do it without the VAG. mine works as follows, driverside - press and hold till window rolled all way down(both) and hold for 10 seconds, do same for roll up and hold 10 secs, then repeat one more time rolll down and hold 10 secs , it will set it to do auto roll/up/down one tocuh. you can do th esame from teh outside with the key to roll up or down windows open door hold .. roll down all way , hold key in position for 10 secs, repeat same in opposite directions until the window works as desired
its in the owners manual [8D]... if this is not your intention .. then just [sm=angrymail.gif]
the coding they're looking for is to be able to roll up and down the windows with with the key fob WITHOUT putting it in the lock; just using the buttons. You can't do that without Vag-com. To just set the auto-up or auto-down, then yea, there's a sequence. You can set the key to roll up or down the windows by holding the unlock/lock button for 5 seconds (i think its 5-10 seconds)
Old Oct 20, 2007 | 11:34 AM
achTTung's Avatar
Well, if you read down a bit on that audiworld tech article, it actually shows a procedure for re-coding thru the radio. I've never put much time into that, but the little I've done was unsucessful.
Durtty=1st w/ link
So far, Im the only one who's posted a link directly to what they needed, and I did it once about a week ago..... so technically..... You're wrong.
I will give vegas credit, he tried, but he doesn't know the secret technique so he can only get to the tech page, not the article directly.
(right click and copy the link from properties, it'll copy with that '40' in the link, while the link from the address bar does not have that. Also, its a .shtml, and you're link was a .html)
BADSLED
Dec 14, 2013 07:28 PM
abarmard
Feb 14, 2012 04:59 PM
iwbafam
Jun 27, 2011 04:09 AM
knyks342
Apr 10, 2011 10:18 PM
Leifer
Sep 14, 2010 03:09 AM
