valves?
Old Apr 25, 2006 | 01:30 AM
True_Pinoy's Avatar
Default valves?
hey guys..can anyone tell me what the N75 H "Race" Valve is used for. Is it to replace your stock by pass valve?..
Old Apr 25, 2006 | 06:23 AM
BadLuckAudi's Avatar
Default RE: valves?
no it doesnt replace the bypass valve it is an electronic boost controler that allows the ecu to hold 1 to 3 more psi and smoothes the boost curves and removes surges
Old Apr 25, 2006 | 11:22 AM
aTiTude's Avatar
Default RE: valves?
I did not know that. Sounds like a good thing. Anybody have experience with it?
Old Apr 25, 2006 | 07:32 PM
True_Pinoy's Avatar
Default RE: valves?
so like..lets say that im at 14 pounds of boost righ now..if i get the n75 race valve, i will be at 16 or 17 pounds of boost?
Old Apr 26, 2006 | 01:33 AM
achTTung's Avatar
Default RE: valves?
Build or buy a boost machine, and control your boost however you want. boost machine works better with teh stock N75. Boost machines can be had (and are explained) on the modshack.info site.
Old Apr 26, 2006 | 06:45 AM
Default RE: valves?
BAAHHH Boost machiens are POS the N75 is much better, lol either way you can hold more boost longer
Old Apr 26, 2006 | 08:39 PM
MeanAudiA6's Avatar
Default RE: valves?
i want to know if anyone has experience with the boost machine or the n 75 race valve long term effects etc i'm leaning towards the boost machine cuz i like steve(owner of modshack) but the n75 is cheaper
Old Apr 26, 2006 | 09:53 PM
achTTung's Avatar
Default RE: valves?
Now, if I'm considered at all intelligent along the areas of TT parts here (not saying I know everything, or even close....) On Audiworld, I'm a f*ckin moron. You may notice that about half my threads here somehow link to someone words, or pics, from Audiworld. I've done LOTS of reading. If you want opinion other than mine, or most anyones from audiforums, try Audiworld, although, much of my opinions came from what I've learned there, so you'll probably get the same answer. They know their ****.
http://forums.audiworld.com/tt/msgs/1479759.phtml
Theres the first thread I came across from a search of 'N75 Race'
It'll work, but the machine is better.
DubbysA6
Jan 22, 2011 11:55 AM
soccergk
Mar 1, 2008 02:13 PM
XtremeR
Jun 15, 2007 01:47 PM
Joeski
Jan 4, 2006 11:05 AM
Joeski
Jan 3, 2006 07:40 PM
