Various Electronic Issues Mk1 2001 225 tt coupe
Old Jun 29, 2016 | 03:58 PM
habererj's Avatar
Default Various Electronic Issues Mk1 2001 225 tt coupe
I have been trying to fix all of the various electronics problems in my car, I assume some of them are related and causing each other. Ill try to detail all of the problems and any help would be much appreciated
The neither window goes up or down a little when the door is opened, it used to but fluttered on and off over time
- related probably the lights dont come on when either door is opened and the lights are in door mode
- the driver door does not unlock or lock with the keyfob or the central button, however when locked manually with the key the car does make the beep noise, if the driver door is locked, and you unlock the car with the fob, then lock it the passenger door will unlock and lock and the car will beep.
- here are the vag error codes for the locking system
01616 - Shareware Version. To Decode all DTCs
36-10 - Please Register/Activate - Intermittent
00955 - Key 1
09-10 - Adaptation Limit Surpassed - Intermittent
00956 - key 2 adaptation limit surpassed
09-00 - Please Register/Activate
01559 - Shareware Version. To Decode all DTCs
58-10 - Please Register/Activate - Intermittent
01559 - Drivers Door
59-10 - Can't Unlock - Intermittent
01617 - Shareware Version. To Decode all DTCs
35-10 - Please Register/Activate - Intermittent
- the cruise control doesn't work, i assume it is not the brake switch because the brake lights work, and i assume it is not the clutch switch because the car needs the clutch to be depressed when it is pressed. The car is having some fuel issues, i replaced the MAP sensor and that helped a lot but it still buckles a little under load. i read somewhere uneven rpms cause the cruise control to come off
- the fog lights dont toggle on or off when the switch is pulled and pushed, they are just always on
- the headlight washers dont work anymore, they dont push out either, they worked when i first got the car back in 2008, but stopped working immediately following
- the horn stopped working, shortly after the airbag light came on( clock spring?)
ZENNON
Sep 16, 2013 10:43 AM
Mykal
Oct 5, 2012 09:43 PM
mickey13172
Mar 26, 2011 12:01 PM
trackstar6
Sep 6, 2010 09:45 PM
carhopper
Apr 13, 2010 07:34 PM
