Velocity stack
Old Jul 23, 2007 | 05:43 PM
auditt225's Avatar
Default Velocity stack
So I was wondering in since I already have an intake, Im just going to buy the air intake duct and put a velocity stack in front of it. Just like a homemade VTA from modshack.Does anyone have any questions about it? Should I do this or not? Also when modshack first came out with the VTA it came with an insulator instead of the canister. Can I do that as well? Im sure I can get it from lowe's or home depot? Just let me know what you guys think. Thanks
Old Jul 23, 2007 | 05:51 PM
cincyTT's Avatar
I'm make believe
Default RE: Velocity stack
I SEE IN YOUR FUTURE.......spending money and not seeing any difference in performance, good luck though
Old Jul 23, 2007 | 06:13 PM
gravitt's Avatar
Agreed. Intake provides minimal performance gains-- mostly it'stheimprovement in throttle feel and louder DV sounds that an intake mod will help.
Old Jul 23, 2007 | 07:23 PM
.clipse's Avatar
SoCal Crew Member
^ hey my TT felt a bit more torque-ier when i put in my vtda. **** sounded like a boxer engine at first
Old Jul 23, 2007 | 07:34 PM
joshuo's Avatar
^^^ lol @ cincy!
Old Jul 24, 2007 | 08:09 PM
achTTung's Avatar
you want velocity stacks, do it like this..
http://www.elitedubs.com/index.php/topic,2275.0.html
Old Jul 24, 2007 | 11:45 PM
racer_x's Avatar
intake will help, get chipped first. if you're ultra-low-budget and not going to shell out the bucks to chip, do the "diode mod" ... do a search for it on the forums. Intake is a great upgrade-- if you asked any of the modders on here if they had stock intake, most would look at you like you were crazy.
slight HP gains stock, more chipped. Better sound, but careful if you're doing it in your garage-- you don't want to be sucking in hot air, so do the insulation and heat shielding properly.
Good luck!
Old Jul 25, 2007 | 12:03 PM
.clipse's Avatar
SoCal Crew Member
you could always do the airbox mod as well. bore at the bottom of the air box and put a k&n drop-in.
Old Jul 25, 2007 | 02:02 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: racer_x
Good luck!
he has just about all the bolts on there crazy
fadeoutmystar
Aug 9, 2008 11:44 PM
PCBOI808@HOTMAIL.COM
Aug 13, 2007 12:21 AM
Blown87camaro
May 10, 2007 04:16 PM
peterancona
Apr 18, 2007 07:09 AM
