what is the correct allen head key size for tranny
Old Apr 5, 2007 | 01:56 PM
auditt225's Avatar
Default what is the correct allen head key size for tranny
So someone on here told me to get a 17mm allen key for the tranny fluid change. I spent about 2 days looking for this part. It turns out its wrong. Does anyone kno wthe really allen head key size?
Old Apr 5, 2007 | 02:03 PM
diehlryan's Avatar
Default RE: what is the correct allen head key size for tranny
I dont know the answer but have you looked into purchasing the Bentley repair manual for your TT?
Might help avoid having to wait for someone on here to answer a ? for you.
Old Apr 5, 2007 | 03:32 PM
MeanAudiA6's Avatar
You WILL need something to undo the plugs. It should be a 14 mm Allen Wrench (that is for my 2001, I hear later years may use different bits), that no one has [edit: I have found a set of 14/17/19 mm wrenches at AutoZone]. In it's place, I used a 3/8" bolt and two nuts. The head of the bolt is 1/2", or 12.7 mm, which is undersized for the 14 mm socket, but it worked...
Old Apr 5, 2007 | 03:33 PM
MeanAudiA6's Avatar
make sure you clean the bevel case magnetic drain plug
Old Apr 5, 2007 | 06:46 PM
225tt's Avatar
How did you re-fill ur tranny A6? Any special tools required...
Old Apr 5, 2007 | 11:03 PM
MeanAudiA6's Avatar
you'll just need a grease gun to push the oil into the fill hole. and the tools listed above. its very easy process. takes 3 qts redline mt-90 i'll post a link to a very good write-up Mcphill(should be on Mr.Schwings foki page listed as a friend)
Old Apr 6, 2007 | 08:11 PM
Dana Reed's Avatar
Buy a 3/8" coupler nut at the hardware store for $1.50 and file it down a tad so it fits the hex properly. Then you use a 9/16" or 14mm socket on the other end. Fill it till it runs out; you can buy a pump at the auto parts store for about $4 that screws into the 1 qt. bottles of synthetic 75-90 (I used Mobil 1).
Consider doing the rear diff as well; a 1/2" coupler nut fits it, plus a little filing as well. 4 qts. will take care of both trans and rear diff.
Old Apr 6, 2007 | 08:20 PM
techbod's Avatar
[IMG]local://upfiles/12092/BB5137E82A704E428ED4441C84E8E253.jpg[/IMG]
Old Apr 6, 2007 | 08:23 PM
techbod's Avatar
there is no drain plug, you fill till it over flows
Old Apr 6, 2007 | 09:14 PM
MeanAudiA6's Avatar
there is deff a drain hole i dont know why those pics dont show it.
