What kind of gains?
Old Sep 29, 2009 | 08:05 AM
jojoenglish85's Avatar
Default What kind of gains?
Hey just wondering mainly if cincy would know, with my current BT setup, what kind of gains/benefits would i see by installing a FMIC and SEM Intake Manifold? Trying to decide if i should spend that cash on rods, or stroker kit. and what kind of gains from a 2.2L stroker kit with 100mm Crank
Old Sep 29, 2009 | 04:04 PM
racer_x's Avatar
you have a BT?
Old Sep 29, 2009 | 06:16 PM
achTTung's Avatar
if you have any turbo, you'll see gains from an intercooler upgrade (I really hope you're not running stock IC's). That should be waaaaay higher on the list of things to do. At least way above upgrading internals.
Old Sep 29, 2009 | 07:36 PM
racer_x's Avatar
will running a big core on the stock turbo promote a lot of lag in this car, or are the 'big' cores small enough to where it doesn't matter?
Old Sep 29, 2009 | 09:39 PM
im not sure, im still running stock ic's yes i have big turbo setup and tune, just wondering if the IC + SEM manifold will give me better gains in performance, and where i would most likely see them via powerband
Old Sep 29, 2009 | 09:54 PM
cincyTT's Avatar
I'm make believe
A manifold with gasket matched small port head on your setup should be worth 30+ bhp. A fmic is badly needed on your setup. SHould gain some psi also since the stocks are really restrictive.
No need to stroke your motor. Spend the money on rods and leave the engine be. If you really want to stroke it, 2L is more than enough.
Ill let you know soon when i run my TR12 (HUGE CORE rated 760hp) on a stock turbo before i install my 35r. Shouldnt be to bad, but the iat's will never rise
Old Sep 29, 2009 | 10:00 PM
ok cincy, so say i buy the FMIC and Manifold, will i have to do anything to make that SEM Mani connect up to my head after replacing the stock one? Or will i just need a new gasket and or should it come with one or can i just buy one of those new plenum spacer gaskets?
Old Sep 29, 2009 | 11:31 PM
cincyTT's Avatar
I'm make believe
The manifold of a 225 is a strait swap. SHould just have to reangle the TB hose some. No need for a spacer. If you get a small port SEM it will bolt right up w/o issue. Some places sell a gasket with it, if not, they should have them on the site. Hit me up one audifreaks, might be able to help you out with your fmic shopping on there
Mya4T
Jun 10, 2007 12:29 AM
AudiMan2001S4
Apr 7, 2007 11:38 PM
NuYorka103185
Oct 20, 2006 10:17 PM
blackflame
Dec 27, 2005 04:16 PM
nextgenerationx1
May 5, 2005 12:49 AM
