What's That Fluid Again
Old Apr 3, 2008 | 01:13 PM
Mininger's Avatar
Default What's That Fluid Again
Looking to change out the plugs and tranny fluid this weekend.
What is that fluid people were talking about that gives you cleaner shifts between 1st and 2nd.
Second..
What plugs should I be running. I don't care if I drop $100 or so on the four, I want the best and coolest running plugs there are.
Ideas????
Old Apr 3, 2008 | 01:21 PM
cincyTT's Avatar
I'm make believe
Default RE: What's That Fluid Again
MT-90 fluid and if you are chipped, BKR7e and 6e if you are not. They are cheap and you can swap them every 15k miles.
Old Apr 3, 2008 | 01:35 PM
randomloginname's Avatar
I just got tranny diff and brake fluids swapped yesterday, and second somehow seemed harder to engage, or more willing ton engage at only higher rpm's :-P Maybe itll take a short bit of driving to get the new sauce all the places it likes to be, I dont know was kind of weird, though I did go redline, and have had the stiffer dogbone bushing put in. If I can track down achttung (hey dude) for long enough, I just need to get idle turned up a bit, I am not sure if that helps people without the dobone bushings though.
Old Apr 3, 2008 | 05:15 PM
Mininger's Avatar
Thanks for the info. I'm gonna try and get it done this weekend.
Any ideas on a good cold spark plug. I was looking at the Denso's, but not sure.
Old Apr 3, 2008 | 08:38 PM
MeanAudiA6's Avatar
i had the denso ik22 and they are pretty hard to gap to the .028 i was very leary of breaking that little a$$ tip. i now have ngk bkr7e...also im running the redline mt90 gonna try the royal purple next...heard the purple is a little smoother in the shifting...who knows tho...worth a try and same price...i will let you know how the NGK run after i start the car tomorrow(hopefully almost done with the timing belt)
Old Apr 3, 2008 | 11:11 PM
themysteryman83's Avatar
ORIGINAL: randomloginname
Make sure youput enough in.It should take at least 3 quarts, more with spillage and such.
Old Apr 3, 2008 | 11:22 PM
already smoother today, think it was just the first few miles, the work sheet i believe had like 4 quarts down so should be all set there. Friggin car is killing me this month with maintenance, but I should be set for a long while. At least I found a TIP shipped for a bill, and might have found a replacement bumper, in silver, with a votex lip nonetheless, will get pics tomm [sm=icon_guiness.gif]This pic only to support the fact that beer is in fact awesome and delicious
MartinCieslak1
Feb 25, 2011 07:51 AM
konabiker47
Jan 20, 2009 09:28 PM
