wheels?
Old Jul 17, 2007 | 05:54 PM
  #41
twenty8red's Avatar
Default RE: wheels?
thanks for the input so far. i've found some pretty good prices and am seriously considering ordering them. my only concern now is if they are wide enough to give any performance benefits over my factory 17s.
Old Jul 17, 2007 | 06:13 PM
  #42
sheepcan's Avatar
Default RE: wheels?
On awd does the tire have to be the exact same size all around or just the same height? Because I would like to have wider tires in the back.
Old Jul 17, 2007 | 06:30 PM
  #43
.clipse's Avatar
SoCal Crew Member
Default RE: wheels?
^you can run a staggered setup on an awd
Old Jul 17, 2007 | 06:37 PM
  #44
sheepcan's Avatar
Default RE: wheels?
Good, I like wider in the back I think its sexy[sm=loveeyes.gif]
So could I go with like 18x8 or 18x8.5in the front and 18x9 in the back??
Old Jul 17, 2007 | 06:44 PM
  #45
cincyTT's Avatar
I'm make believe
Default RE: wheels?
5zigen's are high quality and usually light weight
fat fives are 21lbs
for a staggard setup, the tires have to be almost the same, withen a cartain percent (blown knows i think)
Old Jul 17, 2007 | 06:55 PM
  #46
sheepcan's Avatar
Default RE: wheels?
I found it, it says they can't be more than a five percent difference in circumference.
Is it hard to get a tire wider but the same height?
Old Jul 17, 2007 | 07:08 PM
  #47
.clipse's Avatar
SoCal Crew Member
Default RE: wheels?
stretch out your tires
Old Jul 18, 2007 | 10:02 AM
  #48
twenty8red's Avatar
Default RE: wheels?
also i like the look of the FlikWasphowever the offset is 33, can i run those w/o spacers? I can get the Wasps for about $350 less than the 5zigens with the same tires. Any suggestions on what i should do?
Old Jul 18, 2007 | 11:15 AM
  #49
diehlryan's Avatar
Default RE: wheels?
Stock Audi Wheel offset is 32.. I just put 18x8 with 35 offset on mine.
Spacers will give you a wider stance.
Wheel Spacer Calculator
Old Jul 18, 2007 | 11:19 AM
  #50
joshuo's Avatar
Default RE: wheels?
wider rear tires will uncrease understeer, just so you know...
