when to know u need a new clutch? newbie here.
Old May 15, 2007 | 09:53 AM
megamoe's Avatar
Default when to know u need a new clutch? newbie here.
Hello all,
i was wondering when do i know if i need a new clutch? cause for eample is it normal that the rpm goes up to 4 when i am on 160 and 6th gear?
thx alot, total newbie here
Old May 15, 2007 | 09:59 AM
bmwtoaudi's Avatar
Default RE: when to know u need a new clutch? newbie here.
What? - In the world are you trying to say?
160mph? - 4 rpm's?
You need to be clear in your sentence structure.
However, you'll know when you need a new clutch, you'll hit the gas and your car wont move. - Or it will lag before it kicks in.
ECS Tuning has a great Stage 1 clutch. - I have it installed myself. - It holds like no ones business. - I used this week while attending an autocross event. - I never had a problem downshifting.
Best of luck, and try to be more clear in the future! [8D]
Old May 15, 2007 | 10:01 AM
moeron7's Avatar
Are you speaking english? Can you try and re-phrase that sentence to make sense? Thanks
Old May 15, 2007 | 10:05 AM
neur0tic's Avatar
It almost seems like a weak attempt to fish for pats on the back for going 160mph @ 4000rpm in 6th.
... not very subtle... and not very well done. Just say... "Hey look at me!.." next time.
Old May 15, 2007 | 10:11 AM
megamoe's Avatar
sorry, its 160km/h on 4rpm and 6th gear, thats what i meant is it normal? or the rpm is a bit high
Old May 15, 2007 | 10:15 AM
neur0tic's Avatar
hmm... thats 100mph. that sounds about right. Im at right about 3100rpm at 80mph (128kph)
Old May 15, 2007 | 10:29 AM
cincyTT's Avatar
I'm make believe
When you give it gas and the tach goes, but not the car. That is called slippage and take it from someonewho has been left on the side of the highway with a blown clutch, Change it ASAP.
Old May 15, 2007 | 11:01 AM
moeron7's Avatar
ORIGINAL: cincyTT
Cincy, could that also go for a chipped 225's TIP collapsing? I dont smell any clutch or anything from the engine when it happens, I hope its my TIP and not my clutch!
Old May 15, 2007 | 11:03 AM
cincyTT's Avatar
I'm make believe
Im sure it would feel about the same. Plus if your not smelling anything, its more than likely your car choking. If it bucks, deff the intake.
Old May 15, 2007 | 12:04 PM
Vorais's Avatar
However, if your RPM's are still increasing, but your speed is not, it is likely clutch slippage. They don't always give off a strong smell. The TIP collapsing will cause a lose of power, but the engine speed will be reduced directly (RPM's stop going up as MPH do.)
Scaryfatkid
Apr 19, 2010 07:56 PM
Turbonator
Nov 29, 2008 11:01 AM
Matt_Iliketurbopull
Apr 28, 2007 03:06 PM
Willfulone
Dec 11, 2004 03:50 AM
Nasalcrom
Jun 29, 2004 01:58 PM
