Where can I find a reasonable Pre Cat Wideband O2 Sensor?
Old Jul 30, 2008 | 07:05 PM
tom1222's Avatar
Default Where can I find a reasonable Pre Cat Wideband O2 Sensor?
Hi Everyone,
I searched High and Low and can not find the Pre Cat O2 Sensor with Wideband for my
2004 TT 225. I just replaced the post cat O2 sensor but I was told that the top or Pre Cat
O2 controls the Air/Fuel mix and my car is running rich so I thought I would replace to O2 which
should be done anyhow after 60k+ miles.
Any help or Part Numbers would be greatly appreciated.
Thanks in advance for your help!
Tom in INdy
04 TT 225
Old Jul 30, 2008 | 10:43 PM
GHETTOxWHITExBOY's Avatar
Default RE: Where can I find a reasonable Pre Cat Wideband O2 Sensor?
how rich is it running.........if its chipped its better to be running rich than lean !!! thats how you end up with detonation. not a good thing !!!
Old Jul 30, 2008 | 11:57 PM
cincyTT's Avatar
I'm make believe
rich + no code usually = vac leak somewhere.
Old Jul 31, 2008 | 07:38 AM
tom1222's Avatar
I have the scangauge II and it reads -13 which is rich. + would be lean. It should read between +5 to -5. I am running a 4bar fpr which the Revo Stage 2 calles for. I am also running a 42DD DP, Modshack **** and Boostmachine. I switched back to the original OEM MAF housing but that made things worse and I was running a - 23 rich. I did swap out the lower (Post Cat) O2 Sensor but that didn't really change anything. So I am thinking it might be the Pre Cat O2 sensor since it is a wideband O2 sensor and controls Air/Fuel mixture.
The car runs great otherwise.But it does occasionally blow black smoke out the exhaust when Ifull throttle accellerate.
Cincy,thanks for your input. I have checked all the hoses that I could find and I don'tsee or rather hear any vaccum leak.But I realize they are hard to find.
Thanks for your help!
Don't pay attention to the signature. I know have a 2004 TT 225 which is different somewhat from the 01. Especially in the O2 sensor department.
Old Jul 31, 2008 | 10:23 AM
cincyTT's Avatar
I'm make believe
unless you know what those -5 +5 really mean vs eg 12:1, that info is pretty much a waste.
JordanDufrane
Jul 23, 2013 05:45 PM
dragonrage
Oct 1, 2009 08:10 PM
ghost6303
Jul 19, 2008 08:12 PM
Audi_Skydiver
May 8, 2008 11:14 AM
rafa_207
Jan 24, 2008 04:49 PM
