Where to put power steering fluid?
Old Sep 29, 2008 | 05:22 PM
dfischer's Avatar
Default Where to put power steering fluid?
Hey guys, so here's a pic of the engine:
http://www.flickr.com/photos/danielf...89/2900155090/
I put notes on that image so you can communicate where it is. I pointed out two areas where I think it is.
If anyone could help me out on where to put the power steering fluid that'd be awesome.
Thanks!
Old Sep 29, 2008 | 05:45 PM
shkenned's Avatar
It's on the far left (passenger's side). Sits below that cover....easy to find once you take that cover off.
Old Sep 29, 2008 | 06:17 PM
dfischer's Avatar
Okay so I took off the left cover by the coolant and I noticed a green cap with a "steering wheel illustration w/ water on it". Is this the right thing? I'm trying to take it off and it seems impossible. How do you get leverage on this thing?
Old Sep 29, 2008 | 06:21 PM
achTTung's Avatar
shaft of a screwdriver. lay it across the cap in the little indent. comes off easy like that.
Old Sep 29, 2008 | 06:25 PM
myxyzxo's Avatar
SoCal Crew Member
I was looking on the fact sheet. It doesn't mention anything about what type of oil to use for the power steering.. Also the link of approved oils isn't working anymore.
Old Sep 29, 2008 | 06:36 PM
MeanAudiA6's Avatar
i used the audi stuff the first time...then i have STP the red kind i believe and no issues...power steering fluid is all pretty much the same...syn kind
Old Sep 29, 2008 | 06:44 PM
dfischer's Avatar
Thanks!
Old Sep 29, 2008 | 06:50 PM
achTTung's Avatar
i'd stick with the Audi stuff if possible.
Has to do with interactions with the metals used in the system (my reasoning). G12 coolant doesn't play well with others, you have to be sure to use a GL5 gear oil in the transmission due to 'yellow metal' interactions, just seems safer to use the factory stuff if you can.
Theres a good chance you'll be safe with off the shelf stuff, I just like to cover my bases.
Old Sep 29, 2008 | 07:08 PM
myxyzxo's Avatar
SoCal Crew Member
Well I bought the Royal Purple 10w30 and the Coolant is G12. I think once the car is up and running, I have to take it to a shop for them to change out the transmission fluid. What is type of power steering fluid does audi use?
Old Sep 29, 2008 | 08:25 PM
achTTung's Avatar
Its Audi/VW branded stuff, never looked beyond that.
Killuminati
May 23, 2013 09:18 AM
moeron7
Jan 9, 2008 08:09 PM
bronxblaza117
Jan 9, 2008 06:00 PM
thrax982
Mar 31, 2005 10:15 PM
