While my car cools down...
Old Jun 11, 2007 | 01:16 PM
Anos's Avatar
Default While my car cools down...
I spose ill ask a semi Noob question. Now that I have the C.A.I. on, I can hear the DV very very well now. I remember asking a while back if the DV should Always flutter or at higher rpms just go PSSSHHHH. Well, mine ONLY does the flutter sound unless I smash the gas to redline (to me, that doesnt seem normal AND even then it's questionable if it'll just go pssh. Usually just a loud flutter). I still havent put the Forge on yet since "Professor, turbo, hot." I've been told OEM DV's have a rubber diaphram which is known to rip? could this be the cause of constant flutter?
Hopefully once I get the Forge on there it will work properly. Heading through an underpass lastnight in victor when I downshifted to third then punched it, the 3-4th shift I could hear just a normal PSSSHH. But thats the Only time it's done it.
Old Jun 11, 2007 | 01:37 PM
Anos's Avatar
Default RE: While my car cools down...
This is what I was expecting the OEM one to sound like. However this gives me high hopes for the Forge one now =)
http://youtube.com/watch?v=usPVnPtPuEs
Old Jun 11, 2007 | 02:31 PM
cincyTT's Avatar
I'm make believe
most will flutter with a low amount of boost (~5psi) and be clean over that.
Old Jun 11, 2007 | 03:01 PM
Anos's Avatar
So I finally put the Forge on about 20 minutes ago. I put Only the green spring in there, shimless. What a huge improvement. Drives better, accelerates better. Everything better. OEM valve must have been goofed up since this one sounds just like in the vid I posted. No flutter, clean pssshh sound. Now for the "Tuneing" process.
How will I know if I need to add a shim/different spring into the DV? (I have no boost gauge at this given moment) Is it doable by ear/driving to know if I have got it spot on.
Old Jun 11, 2007 | 03:27 PM
M FLYTT's Avatar
in everyones opinion whats the best DV valve to get... and where's the cheapest place to order it?
Old Jun 11, 2007 | 03:44 PM
Vorais's Avatar
Yes, you want the lowest spring value that does not flutter while under load. However, may I suggest your next mod be a boost guage? They are failry inexpensive and are awesome for trouble shooting other issues if they occur later on.
Old Jun 11, 2007 | 03:52 PM
Anos's Avatar
Yea boost gauge is next on the list. Need to pick a size and find a pod to work with. I don't totally want to lose a vent for a gauge...but eh....Maybe. And Right now there is no flutter at all. I'll add a shim tomorrow when everythings not too hot to handle and see how it goes.
markbjorlin
Jul 15, 2008 11:06 AM
