Window issue
For some reason well before when I closed my windows they would shut & one would reset(?) & roll back down half way but, now neither of them do the automatic roll up when I just flick the switch instead of holding them which is what I have to do now, & when I open the door they don't move down 1/4 of a inch like they used to. Thoughts?
Hello run-on sentence.
im going to try using zero grammar and punctuation to tell you how to fix your problem by explaining the window resest procedure which is done by rolling the windows all the way down thenclick and hold the window down button again after this roll the window all the way up and then click and hold the window up button again this should reset the windows and resume the auto up and down feature and the quarter inch drop feature.
ORIGINAL: moeron7
LMAO, I dont even know if I can do that! Its just automatic
ORIGINAL: diehlryan
He said "hello run on sentence" and used a comma.
Butthe reset should work.If not, roll the windows all the way down and then unplug that battery for a few minutes, reinstall it, and thendo the above preceedure again.
idk probably die or keep going on in life without using and punctuation causing you of course to just live by one big run on sentence which in turn would most likely lead to a boring life which also would lead to your TT dying because you did have us ok really all the really smart guys unlike me but whatever and therefore youd just be sad sooooooooo youd be sad without us
