Window Problem
Old Aug 26, 2008 | 09:11 AM
projlightning's Avatar
Unhappy Window Problem
I stepped out the car and raised the windows to go into the store. 10 minutes later when I'm about to leave, I lower the windows and only the driver side went down. When I hit the switch, I can hear a faint click so I'm assuming it's the window motor. Any thoughts?
Also, do any of the VW window motors fit the TT?
Old Aug 26, 2008 | 09:17 AM
theTTkid's Avatar
not sure about the vw windows fitting, but im assuming you heard the click from the passenger side... was it just one click? or click click click...
Old Aug 26, 2008 | 09:19 AM
Just one click
Old Aug 26, 2008 | 10:43 AM
theTTkid's Avatar
sounds like a motor to me.. sorry broski, id would wait for another person though to chime in because im not all that familiar with window motors yet
Old Aug 26, 2008 | 10:46 AM
TopSpeedCustoms's Avatar
Your lucky its a passenger window. They're cheaper than the drivers side.
Old Aug 26, 2008 | 10:49 AM
Cheapest I've found so far is $207... still looking...
Old Aug 26, 2008 | 09:39 PM
theTTkid's Avatar
207 doesnt seem to bad
Old Aug 27, 2008 | 07:27 AM
ttster's Avatar
Have you determined it is a motor problem and not the regulator?
Old Aug 27, 2008 | 08:40 AM
Local Audi mechanic at the NORTH TEXAS AUDI GROUP, said "It is the window regulator, the motors are solid"
So, I'll be checking both over the weekend. Hopefully it's the regulator since that's even cheaper ($170).
Old Aug 27, 2008 | 09:10 AM
ttster's Avatar
I think you should be able to get cheaper ($145?) for a passenger side regulator (they fail less often because they are used less often then driver side and so there is less demand).
My driver side has a similar problem. Upon inspection, the plastic connector that attaches the cable to the take up reel was cracked causing the cable to slip snarl and snag. Apparently the only way to fix is to replace the entire regulator.
Unless, is there such a thing as a TT window regulator repair kit?
