windows need reprogramming
My battery died and I replaced it. I didn't lose my radio codes, but my driver side window now only operates manually, and it doesn't do that little half inch drop when you open the door. Help.
Using the window control switch. Push and hold the lever making window go all the way down. When the window is down, Lift the switch up. When the window is all the way up, push down again. Do it a few times then it will work again.
up, down, up, down, left, right, a, b, a, b, select, start.
wait... that for the NES....
Actually, what you need to do is hold the switch until the window is all the way up, release, and then hold UP again for about 2 seconds. I think myxyzxo was thinking that, but his wording isn't really clear.
The info on this forum is priceless. I had the same issue. Did the full down, full up, release and up. Worked great, thanks!!!
Just a note, I hope this is right, but I heard/felt the window resetting. I makes a slight click at the end, especially the last step of "up again."
