windows need reprogramming
Old Oct 31, 2008 | 06:14 PM
fireman9585's Avatar
Default windows need reprogramming
My battery died and I replaced it. I didn't lose my radio codes, but my driver side window now only operates manually, and it doesn't do that little half inch drop when you open the door. Help.
Old Oct 31, 2008 | 06:21 PM
myxyzxo's Avatar
SoCal Crew Member
Using the window control switch. Push and hold the lever making window go all the way down. When the window is down, Lift the switch up. When the window is all the way up, push down again. Do it a few times then it will work again.
Old Oct 31, 2008 | 06:32 PM
no luck yet. any other ideas?
Old Oct 31, 2008 | 06:34 PM
achTTung's Avatar
up, down, up, down, left, right, a, b, a, b, select, start.
wait... that for the NES....
Actually, what you need to do is hold the switch until the window is all the way up, release, and then hold UP again for about 2 seconds. I think myxyzxo was thinking that, but his wording isn't really clear.
Old Oct 31, 2008 | 07:07 PM
myxyzxo's Avatar
SoCal Crew Member
^ qft =)
Old Oct 31, 2008 | 07:19 PM
.clipse's Avatar
SoCal Crew Member
^ actually... it's the infamous konami code =)
Old Oct 31, 2008 | 08:33 PM
and that fixed it. thanks.
Old Nov 1, 2008 | 03:04 PM
Fido083's Avatar
The info on this forum is priceless. I had the same issue. Did the full down, full up, release and up. Worked great, thanks!!!
Just a note, I hope this is right, but I heard/felt the window resetting. I makes a slight click at the end, especially the last step of "up again."
Old Nov 1, 2008 | 04:09 PM
RenoRains's Avatar
actually if you read the user's manual it says in there....all you have to do is hold the button when the windows are all the way up until you hear a click...
Old Nov 1, 2008 | 05:11 PM
achTTung's Avatar
pretty much what i've been saying for... ever?
Can't say I've ever opened my manual though, I didn't realize its in there.
Anyway, yeah, the click is a good thing.
