Would 18x9 rims fit on the tt?
Old Feb 11, 2008 | 11:43 AM
PNGreco's Avatar
Default Would 18x9 rims fit on the tt?
I'm looking to buy new rims for my tt. I'v only had it for a month or two now and do not know alot about the tt's. Would I have any problems fitting 18x9 wheels on the car?? Thanks
Old Feb 11, 2008 | 11:47 AM
ouTTie914's Avatar
Default RE: Would 18x9 rims fit on the tt?
Depends on the offset of the wheel.
Old Feb 11, 2008 | 01:55 PM
jojoenglish85's Avatar
they will fit but you will need spacers and that depends on how wide you want to be spaced. But they will fit as long as the have 5x100 bolt pattern
Old Feb 11, 2008 | 02:19 PM
ouTTie914's Avatar
What makes you think he'll need spacers??
18 inch rims are more than big enough to clear the brake calipers...
It depends on the offset to see if they will rub against the wheel well or not...
Considering he's not lowered I doubt it will be a problem, but it doesn't hurt to know the offset to be certain.
Old Feb 11, 2008 | 04:50 PM
Mininger's Avatar
ORIGINAL: jojoenglish85
You don't need spacers unless your looking for a widebody look. I'm running a 19 x 9.5 in the rear and a 19 x 8.5 up front and they clear fine. You can even run a 20 if you want to, but lowering the vehicle then becomes an issue with clearence in the rear.
Typical offset is 35 on the TT. If you only have FWD instead of the Quattro, check with a shop because I believe the rear end is a little different when dealing with spacers (widebody look only)
Old Feb 11, 2008 | 06:38 PM
PNGreco's Avatar
Thanks guys for the help, they are 5x100 bolt pattern, and have a 35 offset. As soon as i get them I'll get some pictures on here.
Old Feb 13, 2008 | 01:34 PM
FasTT's Avatar
im getting the same width...ive measured it all out you'll be fine. im doing 18x8 front 18x9 back with +35 and w/ 10mm spacers rear will clear and be flush
Old Feb 20, 2008 | 01:13 PM
FasTT's Avatar
actually they're +38 rear so this'll change the setup a bit..im lowered too so a bit more headache - if you want i can get you pics once the wheels are on
Old Feb 21, 2008 | 03:38 PM
PNGreco's Avatar
That would be great, what wheels are you buying??
Old Sep 28, 2015 | 11:52 PM
quattro02's Avatar
Default Do yall think these will fit?
http://atlanta.craigslist.org/nat/pts/5212460490.html
GrapeBandit
Apr 23, 2014 03:03 PM
blacksheep
Mar 14, 2011 10:53 PM
fiddyatmac
Sep 22, 2010 07:18 AM
Audacity
Mar 7, 2010 01:10 PM
Makav3li1
Apr 4, 2009 11:31 AM
