$450 for wheel bearing replacement?
Old Jul 17, 2008 | 09:17 AM
mhellman's Avatar
Member
Default $450 for wheel bearing replacement?
Local shop (not dealer) wants $450-500 to replace both rear wheel bearings. Is that about right? I was expecting $300-$350, so it was higher than I expected, but then I'm a cheap bastard who doesn't trust anyone
My normal mechanic can probably do it if it doesn't require special tools. Does it?
Old Jul 17, 2008 | 09:41 AM
scotty@advauto's Avatar
Default RE: $450 for wheel bearing replacement?
That seems high. Only special tools required are a standard wheel bearing puller kit. Time for that job should be about 1-2 hours and the partshould beless than 100 bucks.
Old Jul 17, 2008 | 10:32 AM
klum00's Avatar
easy DIY. pull out the hub yourself and take it somewhere to have the old bearing pressed out and new bearing pressed in.
Old Jul 17, 2008 | 10:35 AM
TDRILL's Avatar
You need to press the new bearing back in too. A lot of these places need to take it to a machine shop to get pressed. Machine shops charge at least $50 an hour and usually more. Not that it necessarily takes that long, but they have a minumum charge sometimes too. That cost gets forwarded on to you which sometimes makes the price higher than you thought it would be. Its going to be cheaper if you find a shop with a press, but thats not all that common.
Old Jul 17, 2008 | 10:56 AM
klum00's Avatar
Guy at a local shop has removed and pressed mine for $20 - $40.
Old Jul 17, 2008 | 01:16 PM
fritz's Avatar
took mine out as well and had it pressed for 40 bucks. 60 for both. both the bearings online, about 150 total
Old Jul 18, 2008 | 12:32 PM
mhellman's Avatar
Member
Thanks guys. I don't even own a freakin' jack anymore, so unless it can be fixed with a flashlight and hammer...DYI is pretty much out for me. My normal mechanic says he can probably do it for about $225. He's not an Audi guy, but he's a good mechanic. He has his own press, but says he may not have the correct adaptor, in which case he'll take it to a machine shop.
Old Jul 20, 2008 | 02:36 AM
01AudiA4's Avatar
DIY Guy at local shop pressed mine out for free and gave me the 14MM allen that i needed also.
Old Jul 20, 2008 | 08:10 AM
hb972.8q's Avatar
first time it cost me $200 for a local guy. 2nd one cost me about 60 for the part and $30 for the install. a buddie ons a shop....
Old Jul 20, 2008 | 09:59 AM
techbod's Avatar
$200 sounds very reasonable and to the others ( the tool that pushes the bearing out also pushes the new one in )
