01 A4 2.8Q - suggestions requested (2 issues)
Old Jul 26, 2008 | 11:17 AM
ChIBoY's Avatar
Default 01 A4 2.8Q - suggestions requested (2 issues)
Hello,
I have a 2001 A4 2.8Q AWD.
The Sunroof does not slide... If I push the button it tilts back but it will not slide. It was working & all of a sudden it stopped. What can I do to bring back full functionality?
When I go to fill up gas it takes a long, long time. It fills up maybe $.50 at a time before it clicks... its very annoying & I have no idea what the problem is.
Any suggestions?
Thanks.
Old Jul 26, 2008 | 11:23 PM
ChIBoY's Avatar
Default RE: 01 A4 2.8Q - suggestions requested (2 issues)
Old Jul 27, 2008 | 12:06 AM
Tweaked's Avatar
ORIGINAL: ChIBoY
Hello,
If the sunroof does not slide at all, you'll likely need a switch
Your tank is likely not venting, possibly due to a sticky or clogged valve. When you push the flap at the filler neck, you should hear a "click in or around the tank." Another possibility is a damaged fill hose. Look in the filler neck for damage.
Any suggestions?
Thanks.
Old Jul 27, 2008 | 08:26 AM
CRAZYHAWK's Avatar
Pull down the light above the rearview mirror. Turn the light off.
Spray the switch with RadioShack Contact Cleaner. Turn the switch
to clean it.
Old Jul 27, 2008 | 10:40 PM
ChIBoY's Avatar
I tried cleaning the switch by putting the contact spray from RD. The switch is not the problem, when I turn the switch to open the sunroof it moves & tries to open but it cant & moves back. What could the problem be? Is there something that can get stuck & prevent it from being moved?
DamoS3
Sep 8, 2011 06:24 AM
Penman
Apr 30, 2008 07:54 PM
Segun
Nov 5, 2007 05:19 PM
Segun
Nov 5, 2007 09:10 AM
mach1usmc
Sep 2, 2007 04:30 PM
