01' A4 no boost with CEL help
Old Feb 21, 2011 | 06:05 PM
Rocklobsta1109's Avatar
Default 01' A4 no boost with CEL help
I have an 01' 1.8t AWM and I'm getting a persistent "lean condition on bank one" code with no boost. I'm trying to track down the issue but im having some problems. The car makes no boost 95% of the time with the CEL on but it will randomly boost for about 30seconds during normal driving then nothing again.
I've checked the DV and it seems to be in decent shape, checked all the vacuum lines to and from the N75 to see that they were in good shape, and checked lines to and from the FPR. Ive run out of ideas so I'm hoping you guys can help me out
Edit: I should add car is all stock automatic quattro
Old Feb 21, 2011 | 06:27 PM
turbo kraut's Avatar
Tech Guru
no boost tends to mean a vac leak... that can also be part of the reason for the lean code... i know i was having a lean condition and part of it was due to a bad maf
have you checked the vac line going to the egr and n80 valve?
that one is kind of hard to see, and can leak
Old Feb 21, 2011 | 10:37 PM
no i haven't but I will check them tomorrow and report back
thanks for the input
Old Feb 22, 2011 | 06:00 PM
I checked the N80 and it seemed to be ok, I took it off and it doesn't leak if I blow through it and nothing came out of it. EGR vac line looks good as well, and I searched for other vac leaks but nothing came up. Ive read that the n80 should click a bit while running, it makes no noise at all, could this be a probem?
TeeterTawter
Jan 20, 2013 12:14 PM
to4xxx
Jun 8, 2012 11:56 AM
BUCKET O BOLTS
Jul 28, 2008 08:15 PM
eliTTe
Oct 11, 2007 04:12 PM
onepoint8tee
Jun 27, 2007 04:38 PM
