01B5 1.8t main issues
Old Aug 23, 2013 | 07:57 AM
A4TurboGuy's Avatar
Originally Posted by CCA4
I'm just going to copy my reply from another thread, should give you a good idea of what you're looking at. Also might want to read the FAQ and the newbie guide. Wall of text incoming!
This quote came from my thread. lol
I ended up De-badging the back. I'm glad I did. I used an 18V drill w/ a 3M rubber wheel. If you do that, keep it wet and be careful not to burn through the clear coat.
Also, the Sunroof might not close when you switch it closed. If that happens just pull the switch down manually and it'll close for you.
Old Aug 23, 2013 | 11:21 PM
TreWright78's Avatar
He said something like that from what Iremember, and yeah I'll post it here when Isee the GTi again.
Old Aug 23, 2013 | 11:26 PM
Since its not mine though and from knowing him, Idoubt he would do that, A4TurboGuy
Old Aug 24, 2013 | 08:00 AM
A4TurboGuy's Avatar
Do what?.....
Old Aug 24, 2013 | 08:18 AM
Clayson's Avatar
Debadging is 99% personal preference.
LMAO.... Where's the other 1%?? And I've seen people spend A LOT of money on the new GTIs with the handle built into the badge on the boot, removing it and getting it smooth and everything.
Old Aug 24, 2013 | 12:20 PM
Doing that
Old Aug 25, 2013 | 08:02 AM
A4TurboGuy's Avatar
Originally Posted by TreWright78
Doing that
As stated previously: Do what feels right to you.....which sounds like leaving it badged. lol
Old Aug 30, 2013 | 04:50 AM
  #18
Haven't been able to get the pic of the GTI, but another thing came up. Just came from a meet and a 07' A4 owner said he used (can't remember) some type of race oil because it's cheaper and the thick oil is better than Mobil 1s thiner oil, and also prevents the oil from burning to bad.. what do you guys think?
Old Aug 30, 2013 | 08:05 AM
  #19
A4TurboGuy's Avatar
If our engines do in fact have sludge issues, thicker oil would only make that issue worse. And if the oil channels are too small, thicker oil won't be able to travel through them as efficiently as it should. The manufacturer recommends a certain viscosity for a reason. I used to run thicker oils, thinking they were protecting better, until I found out they were actually worse.
Old Sep 1, 2013 | 01:46 PM
  #20
CCA4's Avatar
Well for instance: I debadged my rear hatch but ended up having to put a badge back on it to hide a shadow from a bad paint job done by the previous owner. The point I was trying to make is that in 9/10 cases it's going to come down to whatever you think looks best as opposed to when people do **** like put RS4 badges on an A4 and everyone argues about it and flames the crap out of them.
