1.8T 1999 Found oil on my ignition coils and spark plugs
How screwed am I?
EDIT: continued from this thread.
https://www.audiforums.com/forum/sho...80#post1094980
Also read up on some other threads and saw that this may just be some bad seals. Going to talk to a mechanic on monday about getting it fixed.
Valve cover gasket is an easy DIY - save yourself some cash. Also grab the kit from one of the vendors listed in the stickies and save even more!
Here's a few DIY guides if you need:
http://www.a4mods.com/index.php?page...tml&category=1
http://www.taligentx.com/passat/main...vecovergasket/
http://forums.audiworld.com/showthread.php?t=324562
https://www.audiforums.com/forum/diy-do-yourself-55/diy-valve-cover-gasket-tomritt-8418/
if you really have zero tools and cant DIY they are going to charge you $50-100 to install it. but even if you have never picked up a wrench before, this is a good place to start. all you have to do is unbolt you coil packs (8 bolts) and then theres another 8-12 nuts on the cover itself. swap gaskets and retighten the bolts and your done. it will take you an hour max.
CarsVapeandDisney
B8 Models
Jul 6, 2015 12:46 PM
