1.8T 99.0 using oil... Where is it going?
Old May 5, 2008 | 01:44 PM
hartze11's Avatar
Default 1.8T 99.0 using oil... Where is it going?
I have noticed that over the last few months, I seem to be using oil. I have always installed Mobil 1, and never had any engine isses. There is about 88,000 miles on the car. Engine runs great.
Today when I changed the oil, I was probably 2 quarts down (or at least it seemed, it wasn't registering on the dipstick). I didn't see any leaks, nor have I noticed anything on the driveway. I don't see black or grey smoke coming out the exhause, and last week I passed the California smog check without a problem.
Any ideas? Thanks.
Old May 5, 2008 | 02:43 PM
cincyTT's Avatar
I'm make believe
Default RE: 1.8T 99.0 using oil... Where is it going?
Its either has a high oil comsuption or the rings are worn. You should do a compresson test and see if it is the rings. If its not, swapping to a heavier oil will help prevent it from burning off
