1996 Audi A4 quattro Automatic P1504 will not eun
Old Jan 30, 2013 | 07:11 AM
Tupp44's Avatar
Default 1996 Audi A4 quattro Automatic P1504 will not eun
I have a 1996 Audi A4 quattro Automatic 2.8l and i went to pick someone up which took one hour to drive there.It was about -12 c that day ..so when i stop the car turn off the motor and then after he got in ( took about 1 or 2 minutes) I tried to start my car and just the motor turns but no fire
so i got a code P1504
tested
the fuel pump works
the idle control valve voltage good
what is causing this?
please reply because its been 10 days without a car and I have no money
so i need to fix it myself
God Bless
Old Jan 31, 2013 | 06:14 AM
Mark C's Avatar
P1504 is an air intake bypass leak code. In otherwords you have a vacuum leak somewhere, doubt that that would cause a no start condition though, there must be some other issue.
Old Feb 1, 2013 | 08:33 AM
Tupp44's Avatar
No other codes are coming up ...do not know
Old Feb 1, 2013 | 03:07 PM
Mark C's Avatar
Will it start with a shot of starting fluid into the intake? Do you have a way of checking for spark, short of holding the wire while someone else cranks it?
Tupp44
Jan 30, 2013 08:09 AM
vtraudt
Apr 15, 2012 11:29 PM
spyda63
Jul 1, 2007 12:02 PM
jmorris1@vt.edu
Mar 31, 2007 01:04 AM
