1997 A4 2.6 Quattro Manual - Starting Problem
Old Mar 4, 2008 | 07:39 PM
sf_reed's Avatar
Default 1997 A4 2.6 Quattro Manual - Starting Problem
Hello -
I have an intermittentproblem starting my A4 (model 1997 2.6 Quattro Manual Sedan). There is a problem with the ignition switch in that it doesn't flick back and required to be turned back manually but I don't think this is part of the problem.
Essentially the car turns over and appears as it will catch and then it just stops. This may occur 1,2 ... 5, .. 10 times before it finally starts. It occurs mostly when cold but also when warm. It appears to occur more when the car has it's nose pointed slightly uphill but this isn't always the case.
Not being much of a mechanic my thoughts are that perhaps its a fuel pump or fuel line issue in that the engine sparks and it's not a battery issue.
Any thoughts would be appreciated!
-Scott.
Old Mar 4, 2008 | 07:54 PM
auditech79's Avatar
Default RE: 1997 A4 2.6 Quattro Manual - Starting Problem
2.6? or 2.8?
There is a recall out for your ignition switch, get that replaced for free before doing anything else.
Old Mar 4, 2008 | 07:56 PM
qUaTtRoA4's Avatar
sounds like a fuel primming issue...does this happen when the car is warm, like when you go to the store and leave 30 minutes later is starts right up, but when the car sits for a couple/few hours it wont
Old Mar 4, 2008 | 08:01 PM
SAudi's Avatar
its probably the ignition switch like auditech said.
Old Mar 4, 2008 | 08:13 PM
qUaTtRoA4's Avatar
^most likely, but I had a similar problem with a fuel pump as well
Old Mar 4, 2008 | 10:53 PM
sf_reed's Avatar
Thanks all for the quick reply! I have called Audi in regards to the recall and apparently that only applied for North America, not the poor cousins down here in Aus. Looks like it's going to be an expensive exercise finding out
Old Mar 4, 2008 | 11:50 PM
01AudiA4's Avatar
OHh just tell them you had it imported from the US and get it for free.
gemstyles
Dec 13, 2014 04:38 PM
mrp0p1nfr3sh
Sep 22, 2008 01:46 PM
a4audia4
Dec 24, 2007 10:53 AM
nrosei4
33
Aug 29, 2007 06:34 PM
xkon
Jul 8, 2007 12:02 PM
