1997 a4 2.8 stutter
Old Jan 12, 2010 | 02:03 PM
hammy1's Avatar
Thumbs down 1997 a4 2.8 stutter
hey guys recently i did the valve cover seals on my audi and a little after that i noticed when the car is warm it has a stutter like its about to cut off and die but then it catches back itself and continues reving fine itll do this freq while idling and when driving if i floor it the car performs as if its flooding? has a serious hesitation on take off.. any ideas what this could be? i also did a full tune up including cleaning the maf and throttle body, new spark plugs, new wires, and a new air filter.
Old Jan 14, 2010 | 04:45 AM
hammy1's Avatar
so im guessing no one knows what this is?
Old Jan 14, 2010 | 05:08 AM
Mr. Phil's Avatar
idk, my car stutters at idle too... sometimes it goes so low on idle the dash lights come on then car goes back to normal idle lol... but it nevr bogs on acceleration, but i have no idea what the probem is... i really dont care though haha
Old Jan 14, 2010 | 12:07 PM
dragonrage's Avatar
Lots of possibilities. Here are some, not in any particular order.
Vacuum leak (bad lines, a connection that popped off, etc.)
Spark plugs
Ignition coil(s)
Fuel injector(s)
clogged fuel filter
clogged catalytic converter
bad/dirty MAF sensor
bad front O2 sensor(s) (does the v6 have 2 fronts? probably)
REALLY clogged air filter (doubt it though)
etc.
Got a check engine light?
I'd try Sea Foam through a vacuum line to start with.
Old Jan 14, 2010 | 01:26 PM
jokeabus's Avatar
I'd say probably vac lines or fuel filter
Old Jan 14, 2010 | 01:56 PM
Andrew149's Avatar
Coil packs is the most likely
Old Jan 16, 2010 | 09:23 PM
Interceptor's Avatar
Vac lines and also check the pcv system. Mine has an up and down idle sometimes and stalls. Last year had to take apart the pcv system and clean the throttle body and icv. This cured it but its back again so I am replacing other items..Suction pump etc. Car is sluggish and this only happens when winter hits.
Yamaha822
Jul 24, 2014 01:58 PM
SunnyShaida
Dec 15, 2008 06:56 PM
QPower95
Jul 8, 2008 07:26 PM
audi2000
Aug 25, 2007 12:10 PM
qsales37
Aug 13, 2006 07:12 PM
