1997 audi a4 b5 1.8t. Wont crank or start
Old Oct 29, 2018 | 06:21 PM
Mark Legarda's Avatar
Default 1997 audi a4 b5 1.8t. Wont crank or start
Hi guys. I posted earlier and I still need yall help. I seriously dont know what else to do. So just a little back ground. When I got the car to restore it it had a bad clutch and i change that. So after changing the clutch. The car was starting and running. I let it idle and warm up and at first my ignition is bad and had no grease because it gets stuck in crank position and yo uh would have to manually put to acc. but after i shut it off it wouldn't crank again. I thought it was the starter because it was stuck in crank I'm thought I burnt it so i changed that. And still nothing. I change the ignition switch and still nothing. I've already change the fuel pump and I know that's working. I've test light the starter and also bench test the starter and it's working. I dont know what relay it is for the starter. Also i want to let you know that the car was starting while in gears as well before but now it's nothing I get every lights but no crank. Please help. I need yall help.
Mark Legarda
May 14, 2019 08:59 AM
Spencer Bernard
Dec 13, 2016 11:00 AM
waynegw
Oct 19, 2008 09:24 PM
Iowa A6
Oct 29, 2007 11:12 PM
