1998 A4 1.8T Quattro, fuel pump removal
Hello all,
I'm looking for a good guide to help me get the fuel pump out of my 1998 A4. I've searched these forums, but haven't been able to find anything. Any help would be appreciated.
Thank you!
Thank you!
DIY: Changing the Fuel Pump to an A4 Audi | eHow.com
But instead of their Step 1, I would pull the fuel pump fuse while the engine is idling to remove pressure from the fuel lines (look in your Owner's Manual for the fuse diagram).
I agree. My car is FWD though, not Quattro, so I'm not sure if that makes a difference.
does it crank like it wants to turn over or just nothing? if it cranks but wont start check for any leaks in the vacum lines. also touch or listen to ur fuel pump relay if it clicks while u crank over the car. fuel pump relay is under dash, under steering wheel its fuse number 287 i think.
blitztc06
Aug 21, 2010 01:58 PM
