1999.5 Silver A4TQA B5 needs hood & front end help
I'll be posting in buy/sell section too, but was hoping for leads on a used silver hood, and maybe some general advice about aftermarket/oem/used choices from the B5 community.
Especially interested to hear from anyone in or around Columbus Ohio that has parts!
I swear, I wasn't driving, but I do have an A4 that got caught a little to close to the back of an F150 pickup. The hood, radiator support, radiator, fans, etc got mashed. The bumper and skin got off with just a scuff, since it was below the F150's bumper.
This was very low speed, and other than the hood, it looks like everything that is busted or bent is bolt-on.
The patient:
1999.5, A4 1.8T Quattro Automatic,
(one piece headlamps)
AEB engine code
DVT automatic transmission code
330xxx Vin (last 6)
LY7M, Paint code (Aluminum Silver Metallic)
The parts list:
I'm leaning to going used OEM on the big ticket items, but priced what aftermarket I could find at ECStuning.
Quantity description each
1 Silver hood with grill and logo, or just a hood and I'll go with badge-less grill
1 058 121 301 B, viscous fan blade
Meyle - Fan Blade ES#2911 $39.40
The big, belt driven blade, mashed in to radiator, no winners in that battle.
1 058 121 350 , viscous fan clutch
Sachs - Fan Clutch ES#1713 $109.95
Bent beyond repair.
4 Genuine Volkswagen / Audi - Heavy Duty Hex Bolt, Self Locking-(6x14) ES#6893 $0.31
Attaches fan blade to fan clutch, should be replaced every time it's removed, Four per car
1 058 119 145 , viscous fan pulley
Genuine Volkswagen / Audi - Pulley, Fan Clutch ES#6891 $26.91
Pulley behind the big fan and viscous fan clutch. Not noticable bad, but not worth the risk to reuse.
1 Meyle - Cylinder Head Cooling Flange ES#2913 $5.82
Located rear of cylinder head
1 Bilstein - Coolant Sensor Retaining Clip ES#3055 $0.55
1 Victor Reinz - Sealing O-ring ES#2469 $0.99
For cylinder head cooling flange (36x3.15)
1 OEM Coolant Temperature Sensor With O-Ring ES#2832 $19.26
Square Blue 4 pin sensor. With square connector.
1 Geba - Water Pump Assembly W/Housing ES#5407 $89.95
Since the engine ran with little or no coolant, so even though it was replaced a few thousand miles ago, I'm thinking it will be smart to do it again. It sqeaks a little if you turn it by hand
1 8D0 959 455 C, electric fan assembly (Valeo)
Vemo - Radiator Electric Fan Assembly ES#1693 $149.95
The fan, the lead wire and motor were all damaged. Considering used OEM for this.
1 8D0 261 401 H, A/C condenser (403 H may be replacement)
Vaico - A/C Condenser ES#1947 $199.95
May go with used for this. Probably can be had for $50.
1 8D0 121 251 M, cooling radiator
Behr - Radiator ES#1690 $194.95
This brand has some bad reviews on one of the Beamer forums, so I'm looking at other options or used OEM.
1 ECS Accessory Belt Kit ES#52, all three belts $33.30
2 Pentosin - Lifetime Antifreeze (G12), Pink In Color, (1.5 Liters) ES#550 $12.13
OEM replacement fluid for all vehicles that came with pink (G12) coolant
1 CRP - OE VW B5 Passat / Audi B5 A4, Engine Mount - Left Side ES#1966 $44.95
CRP from Germany
1 Meyle - OE VW B5 Passat / Audi B5 A4, Engine Mount - Right Side ES#1967 $49.95
CRP from Germany
1 APR - Snub Mount- Black ES#633 $39.00
1 8D0 941 003 AQ,L driver side one-piece headlamp
1 8D0 941 004 AQ,R passenger side one-piece headlamp
1 8D0 305 594 A, radiator support
1 058 129 617 A, Intake Snorkle
1 8D0 823 509 L, lower hood latch
1 4B1 971 021 , hood switch wiring
1 ? , hood switch
1 8D1 971 725 C, A/C? sensor wire and connector
Not crash related but want to replace
8 Bosch - Injector O-ring-Priced Each ES#6562 $2.49
Fits upper & lower section of injector
1 Bosch - OEM Air Mass Sensor (MAF) ES#1580 $179.95
Open to other suggestions here. But I'm thinking this is the cause of so many check engine light issues, I'd like to take it out of the trouble-shooting equation.
Thanks to any willing to respond!
The patient:
AEB engine code
330xxx Vin (last 6)
The parts list:
Bent beyond repair.
CRP from Germany
CRP from Germany
1 ? , hood switch
I wouldn't have even considered doing this, but I did an engine swap last fall due to sludge, so I've been down this road before. (Thank you AudiForum!)
If it was a bunch of body damage, I wouldn't do it either. But the hood is the only body damage, and its bolt-on. I'll have to pay someone to paint the bumper skin, and the hood (if I can't find a clean used silver one).
(Still had the engine lift in my garage that I borrowed from the brother-in-law.)
Can't really help you with parts other than to recomend www.shokan.com for the hard to find stuff.
I'm in columbus too. Hit me up if you ever need assistance with anything. I have vag com too
Tlag
Sep 1, 2008 02:20 PM
