1999 A4 quattro 2.8l coolant leak
Old Aug 19, 2011 | 10:25 PM
BlKAudiA4's Avatar
Default 1999 A4 quattro 2.8l coolant leak
I have a ridiculous coolant leak on my 2.8q and when i went under to look at it it looks as if it was coming through the transmission? how much would that be to fix or is there any kind of way i can do it myself?
Old Aug 20, 2011 | 11:12 AM
jdahlen24's Avatar
Can you see any obvious leaks in the hoses?
If not, it could be the overflow tank or the cap. If the tank and cap have never been replaced, it's time anyway.
Old Aug 21, 2011 | 01:07 AM
BlKAudiA4's Avatar
i took out the tank and i poured down the hose and it came out like a minute later
Old Aug 21, 2011 | 10:59 AM
raudi28's Avatar
why should the tank and cap be replaced? i have 100k on my car and mine is original. should i replace?
Old Aug 21, 2011 | 12:44 PM
jdahlen24's Avatar
Well, it depends if you want to practice "preventative maintenance" or not. You could always wait until they started leaking. If you have 100k miles on the originals, it's only a matter of time.
My original coolant expansion tank started leaking at about 75k miles, and I had it replaced. That replacement tank started leaking this past spring at 123,000k miles. So now I have a new tank & cap, and I also took the opportunity to drain the old coolant and fill it with fresh G12 coolant while I was at it.
Old Sep 28, 2011 | 04:52 PM
darawilliams's Avatar
It's best to just replace the tank if its at 100k mine just now started leaking I lost a whole tank of coolant in a couple days and you shouldn't pay anymore than $50 to fix it
Old Sep 28, 2011 | 04:53 PM
And I just got to 111k and it started leaking
x4u2sm0ke
Jul 27, 2015 02:43 PM
awol4844
Oct 2, 2012 07:45 AM
shipsta
Jun 16, 2012 12:12 PM
Ammerius
Oct 7, 2011 07:34 PM
amac
Jul 16, 2011 10:12 PM
