1999 starting issues
Old Mar 11, 2009 | 10:44 AM
BioRebel's Avatar
Default 1999 starting issues
I had been having a bit of an issue for a while with my audi, the engine would turn over but would take a while to actually start. I just thought it was the cold air. Well saturday came around and when I turned the key, the car didn't start at all.
After a few seconds blue smoke started to come from the steering column. A few minutes after that the starter would go off every time you fully depressed the clutch.
Well my mechanic said he replaced the ignition switch, which wasnt hat big of an issue, but he thinks he saw the car act a bit funny when he took i on a test drive. He said it may also be a relay inside the car. The last thing he wants to replace is the starter.
Any suggestions?
Also is there any cheap fix for that ABS control module? I finally got that problem too and I'm getting really annoyed that theres no recall for this $2000 unit. I just spent that much replacing the damn rotors I have.
Old Mar 11, 2009 | 11:03 AM
Interceptor's Avatar
Def sounds like ignition related with that problem. Relay and the switch.
As far as the abs problem there should be a guy on ebay and on here I believe that you can send it in and get it repaired. Far less then $2 grand. I will see if I can dig it up.
Old Mar 11, 2009 | 11:11 AM
BioRebel's Avatar
Thanks, any help is appreciated.
And i was kind of having some issues with my blinker not working properly. So should I tell him its the relay? He had suggested that it might be the issue.
And with the bad weather finally over I'm sure I can just leave the abs alone till I get enough cash.
Old Mar 12, 2009 | 01:18 PM
BioRebel's Avatar
Does anyone know what relay I should be looking for? I can't seem to find the part # for the 1999 year model. Is it the same as the 1998 or 2000 model?
audiltr
Mar 20, 2014 10:19 PM
Oh4A4
Feb 11, 2011 07:06 PM
afa4turbo
Oct 4, 2010 09:45 AM
PatrickA6
Sep 15, 2009 09:36 PM
havercamp
Jan 29, 2006 06:35 PM
