2.8 30v Twin Turbo
Its about $200 for braided steel oil lines like the OP for just one turbo. I thought you have done this before? You can shave a couple $$ if you use aeroquip lines, but they dont look as nice.
ORIGINAL: chaos92287
i still want to know where he stuffed 2 gt30's [>:]
ORIGINAL: cincyTT
where would you of put a gt40? If those are 3071r's, the .64 housings he is using should be fine for 3cyl and 1.4L while making the same power, probably more, than a gt40 would.
ORIGINAL: cincyTT
not only that but what even happen to hard lines? imo they look fine, work just as well and they are WAY cheaper. the problem ive found with them is they can be a bit*h to put in sometimes.
on another note: how much would you 2.8 30v guys pay if someone made a kit similar to this but with gt28r turbos and no software?
The fittings cost a decent amount. First you need the fitting for the block for the -4 line, then the line, then the fittings and restrictor for the turbo. Then the turbo drain, -10 line, and then a new fitting for the pan. Parts add up when the fittings are $5-20.
Please GOD, tell me your joking about hardlines. Engine movement + hardlines = bad things.
ORIGINAL: auditech79
It really doesn't matter if you have forged pistons if your still running a 2 bolt main.
If you up-graded to a 4 bolt main like the S4 has then you could push some serious power.
Unitronics is where i would start for a tune myself.
ORIGINAL: cincyTT
ORIGINAL: cincyTT
as for the soft lines, i like how these fittings look. its what i used on my fuel system.
for the fittings (i like how the black fittings look):
http://www.jegs.com/webapp/wcs/store...57777_-1_10019
for the line (i also like black lines but they dont make the in an-4):
http://www.jegs.com/webapp/wcs/store...45139_-1_10019
lets see 2 an-4 fittings 2 X $8, 2 an-10 fittings, 2 X $10.50, 3 feet of an-10, $21.50 3 feet of an-4 line $16. thats what... like $75, i just saved you a bunch of money.
ORIGINAL: jonus079
i could be completely wrong here but are you sure they dont use the same blocks for the 2.7t as the 2.8? ive seen exterior pictures for both and they look identical. the 2.8l even has the ports for the oil return but they car blocked off by a plastic cap.
LOL, you saved me a bunch of money? Your still missing the fitting for the block and oil pan. Both are over $15. WHere are the turbo fittings? Thats another $35. Yes, you can make your own lines for less, but not where your thinking.
lol cincyTT i know turbo prices. if i go with my swap idea im looking at (i think im gettin the name right) the Gt2X. i know im gonna have to bite the bullet on about 1500 bucks worth of accessories. only time and $$$$ will tell.
thats some nice custom work for those twin turbos. clean.
