2.8 timing belt help
Old Sep 6, 2008 | 06:44 PM
merickel's Avatar
Default 2.8 timing belt help
So I am sick of searching. Have gone throught 35 pages of searching and cannot find anything about 2.8 timing belts. I have a 2000 2.8Q A4 that is about to hit 80k and i need to do the timing belt replacement. I am assuming that the tensioner also needs to be replaced and am wondering where a good place to get the whole kit is. I remember seeing someone make a suggestion on here a while back but cannot find it for the life of me.Also, is there anything else that needs replaced around this milage? Any help would be much appreciated. Thanks.
Old Sep 6, 2008 | 11:20 PM
beem's Avatar
I think I bought mine from Blauparts. You can also Google the models parts. Change the waterpump and all the pulley bearings. They don't cost that much and saves the hassle of a failure later which could be very costly. When I went into mine the only suspect bearing was the water pump (slightly loose) but I changed everything. Buy the Bentley manual, it is worth it. B.
Old Sep 7, 2008 | 12:05 AM
coleA4's Avatar
Ecs or Blau but youll need the tool or the know how for making your own.
Old Sep 7, 2008 | 12:11 AM
kendalll's Avatar
www.ecstuning.com probably has all sorts of kits.
Old Sep 7, 2008 | 12:18 AM
lumend13's Avatar
so, Have gone throught 35 pages of searching and cannot find anything about 2.8 timing belts.??? where did u search???? there is a lot of info in this forum about that.... you need timing belt and water pump at the same time.... ectuning its a good place i can recommend that...
Old Sep 7, 2008 | 12:47 AM
onepoint8tee's Avatar
Old Sep 8, 2008 | 01:29 AM
merickel's Avatar
Hey thanks guys. Really helpful.
Audiguruforyou
Sep 20, 2011 01:31 AM
vtraudt
Apr 1, 2011 09:40 AM
TheBat
Jun 20, 2008 01:14 PM
