2.8l 12V - crank vent suction and seafoam - now O2 code?
Old Jul 29, 2012 | 07:58 AM
vtraudt's Avatar
Default 2.8l 12V - crank vent suction and seafoam - now O2 code?
Found a hole in one of the PCV hoses, also found the crank vent suction pump (the plastic Y) plugged (the side tube; 3rd one I replaced on various of my Audis).
Did seamfoam the intake through vac line, and sprayed TB as good as I can through the intake tube (MAF unplugged, corrugated intake hose removed).
Now showing code:
17514 - Oxygen (Lambda) Sensor; B2 S1
P1106 - 95-00 - Voltage too Low / Air Leak
Is that from the seafoam coating the O2 sensor? B2 S1 is upstream O2?
Will it go away or do i need to clean O2 (and how? burn with torch?)?
Old Aug 23, 2012 | 05:13 PM
vtraudt's Avatar
The code is still coming back.
O2 sensor (upstream or downstream; bank 2 is driver side/left side?)?
Or air leak?
boostedLTH
Jan 23, 2023 11:47 PM
AudiTurbo
Jan 7, 2014 02:29 PM
kovalchuk71
Apr 23, 2009 10:13 PM
superdooperme
Nov 26, 2008 10:53 AM
skeezo3000
Sep 4, 2008 11:45 PM
