2000 1.8 brake pad wear indicator light
Old Apr 28, 2013 | 07:18 PM
hartsoe1's Avatar
Default 2000 1.8 brake pad wear indicator light
I've been getting in intermittent brake pad wear indicator logo in the OK box recently. I have recently done front rotors and new plug in pads. Just for my education, what causes the idiot light to come on? Does excessive wear cause the circuit to open, or close? Because if this doesn't go away I'm going to straight wire the plug down at the bearing housing to close it. And, I am assuming that the rears only have physical noise makers. I've changed pads a bunch but never really paid attention to how the wear sensors work. Thanks
Old Apr 28, 2013 | 11:09 PM
CryptoStorm's Avatar
They are normally open and close the circuit by wearing against the rotor.. Pretty self explanatory if you take your disk off and have a look
Old Apr 28, 2013 | 11:28 PM
redline380's Avatar
Legal Moderator
i do believe the circuit is normally closed, and opens once the pad wears enough. you could throw a paper clip in to close the circuit and the light should go off
there are no wear sensors in the rear
Old Apr 28, 2013 | 11:46 PM
Your right.. I wouldn't bypass it though as it is a nice feature that isn't very costly to maintain
Old Apr 29, 2013 | 09:13 AM
hartsoe1's Avatar
the older my car gets, the harder these nice features are to maintain....... Thanks
hartsoe1
Aug 26, 2013 05:08 PM
hartsoe1
May 25, 2013 05:26 PM
domnf15
Sep 14, 2010 06:26 PM
yenkonova
Mar 21, 2009 02:50 PM
eliTTe
Jun 8, 2007 02:08 PM
