2000 1.8t a4 LOTS of problems
Old Jun 3, 2012 | 06:57 PM
riikiiee's Avatar
Default 2000 1.8t a4 LOTS of problems
Hey Im new to this forum but I have made a lot of research about my problems havent got a concrete answer for them
first, i have the crank but no start problem
but after about an hour it starts
then the car overheat really fast, after 10 minutes the needle is in the middle already and the hood is to hot to touch for more than 3 seconds
im getting horrible mpg, and the car also smell like gas sometimes
CEL is on also, and i need it working at the end of this week because im trading it for a civic si
if anyone can help please
Old Jun 3, 2012 | 07:09 PM
Sheasta's Avatar
Its supposed to be in the middle thats operating temp. Does it go above that? Misfiring? (shaky) got a scan tool? Whats the code for?
Old Jun 3, 2012 | 07:22 PM
riikiiee's Avatar
well yeah it goes to the middle, but i have had several cars before, and none of them that hot, codes I will check them tomorrow with a friend
Old Jun 3, 2012 | 07:23 PM
riikiiee's Avatar
and no its not shaky, steady idl rpm too
Old Jun 3, 2012 | 07:41 PM
Sheasta's Avatar
Yea. Is it a 1.8t? Ive noticed they run hot. Had mine about a month. Just did a thermostat on it and it stays right in the middle. (it was at 1/4 with thermostat partially stuck open). Probably gonna need to see codes to further assist you. Maybe you got 02 sensor issues. What did you do to fix the crank no start?
Old Jun 3, 2012 | 08:13 PM
ImTheDevil's Avatar
Wondering if the cat is clogged - that'd superheat the turbo and cause the hood to be hot (do you have the heat pad under the hood?), it'd explain the shitty mpg, and the choking back pressure could keep the car from starting...
Old Jun 4, 2012 | 12:49 AM
riikiiee's Avatar
yeah, ill see if i can post the codes tomorrow after school
whenever it wont start, i just let it be there for 30 minutes, but when im in a hurry I use a fast ignition fluid
Old Jun 4, 2012 | 12:54 AM
riikiiee's Avatar
yeah i have the heat pad, but it seems like it doesn't do a thing
and I have thought of the possibilities of the cat, because it decelerates quickly when i take the foot off the brake
Old Jun 4, 2012 | 09:55 PM
riikiiee's Avatar
Well Im back
I checked with the VAG COM
and the only code is p0441
can this cause all my problems?
Napior
Audi Q7
Oct 31, 2013 10:00 AM
willowtreexx
May 18, 2008 01:28 PM
indoplaya313
Oct 6, 2007 11:18 PM
dombombBMX
Sep 13, 2007 05:04 PM
Mosie84
Sep 21, 2006 02:19 AM
