2000 1.8t runs poorly
Old Jul 10, 2008 | 12:17 AM
tslennon26262's Avatar
Default 2000 1.8t runs poorly
ok, so i start my car this morning, its idling at 1200 rpm, wont go above 3000 rpm, and wont go above 45 mph. i pulled 5 misfire codes, a p0300, which is random misfire, and one for each cylinder. im sort of new to the way audis are made, and i was wondering how some of you fixed it. i would figure that probable causes are the spark plugs, fuel injectors, or a timing belt.
Old Jul 10, 2008 | 12:46 AM
Tweaked's Avatar
Default RE: 2000 1.8t runs poorly
Year, trans, and mileage, please.
When was your last service? Have you checked your spark plug gap? When was your fuel filter last replaced? Is your air filter filthy? Have you tried unplugging your MAF to see if the car runs better?
Old Jul 11, 2008 | 04:14 PM
its a 2000 1.8 turbo with a 5 speed
Old Jul 11, 2008 | 05:33 PM
Tweaked's Avatar
-Have any of the coil packs been replaced?
-Do you have access to a VAGcom to check 02 sensor info, MAF readings, and fuel trims?
Old Jul 12, 2008 | 12:41 AM
the only thing i got is a little mac et50 that tells me codes and if the monitors run, but i dont have the VAGcom. how much is it, and is it a program for your computer?
influentialsonny
Nov 13, 2013 06:30 PM
millenia
Mar 7, 2009 02:34 PM
AGreen
Feb 4, 2009 11:32 PM
rapcat
Jan 15, 2008 02:39 PM
kristokes
Jul 9, 2007 10:35 PM
