2000 A4 engine tapping
Old Jun 30, 2008 | 09:24 PM
rkh3's Avatar
Default 2000 A4 engine tapping
From theleft side top. Iam selling the car and while I've noticed it somewhat before a buyer noticed it today. Not loud and more pronounced at start up. Thoughts? Would Lucas help?
Thanks
Old Jun 30, 2008 | 10:14 PM
ImTheDevil's Avatar
Default RE: 2000 A4 engine tapping
Start with a Seafoam treatment - it can work wonders. If it's a tap because you are not getting full valve lubrication, Seafoam may break the blockage away. The 1.8T is known for oil sludge, and Seafoam will be your best friend.
Old Jun 30, 2008 | 10:17 PM
outasflyguy's Avatar
here's a noob question.... How do you seafoam the engine?
Old Jun 30, 2008 | 10:19 PM
ImTheDevil's Avatar
Hit up the Search feature up top - type in "seafoam 1.8t" and you'll get about four trillion threads. Also, either on www.audiworld.com or www.audidiy.com there is a tech article for the 1.8T that shows step by step what to do.
Old Jul 5, 2008 | 12:56 PM
rkh3's Avatar
So, I ran Seafoam through the engine. While it was in there the noise went away. After 70 miles I did an oil change & now the noise is back. I would think that with the oil so thin the noise would have been worse with Seafoam in the oil. Any insights???
Old Jul 5, 2008 | 07:38 PM
rkh3's Avatar
bump
Old Jul 5, 2008 | 11:17 PM
Tweaked's Avatar
ORIGINAL: rkh3
Would Lucas help?
No.
Old Jul 6, 2008 | 08:03 PM
rkh3's Avatar
I'll see what a qt of Lucas does for it tomorrow.
Old Jul 6, 2008 | 08:24 PM
1.8tee's Avatar
Tapping is caused by an exhaust leak like a crack in the header, also could be a worn belt or pulley.
Old Jul 6, 2008 | 10:58 PM
Tweaked's Avatar
ORIGINAL: rkh3
Nothing.
