2000 A4 Head Gasket
Old Mar 20, 2013 | 03:24 AM
blackline69's Avatar
Default 2000 A4 Head Gasket
I'm going to try to replace the head gasket on a 2000 A4, what am I getting into? Is there anything else I should replace while I'm replacing the gasket?
Old Mar 20, 2013 | 12:25 PM
EthanB5( auditek)'s Avatar
Tech Certified
mainly all the other gaskets that you will be removing, why are you doing the head gasket?
Old Mar 20, 2013 | 03:09 PM
mtroxel's Avatar
What he said. That's not a common problem on these cars.
What motor?
Old Mar 20, 2013 | 10:50 PM
Its a 1.8... there is water in the oil and white smoke. Car starts and runs good.
Old Mar 21, 2013 | 09:19 AM
Tech Certified
there is coolant in your oil? ok ( hoping that you dont have the wrong coolant in your car NO GREEN COOLANT!!!) pop open the coolant reservior, see if your coolant looks like a " milshake" it will look all oily and gross like a milk shake from the gutter
if thats the case... its not a head gasket thats your oil cooler that failed internally
Old Mar 21, 2013 | 09:21 AM
Tech Certified
a LOT easier job then a head gasket too if you're curious
AudiTurbo
Jan 7, 2014 08:03 AM
evilkowz
10
Jun 22, 2010 11:48 PM
kuka
Aug 20, 2009 02:30 PM
frizle2001
Jul 9, 2009 12:30 AM
brian58503
Apr 13, 2009 01:22 AM
