2001 a4 1.8t starting problems
sorry bud. it gets hard from here if i can't actually work on the car. is your car by chance a 2.8? this is weird and i blame it on leaky injectors but a few of the cars i work on have this issue. you need to hold the gas pedal to the floor when you start it. this is clear flood mode. the injectors will not fire. its only on the 2.8's i've seen this issue and i will have to go to someones house becuase their audi wont start and the pedal to the floor fires it right up. after someone see's that they dont really care to have anything fixed because its easy enough to remember to do that.
Why dont you take a pair of vise grips and pinch the fuel return line off from the fuel rail and see if that makes it start easier and run better, by doing that it can build more pressure and itll narrow it down to a pump or fpr. just a thought..
Did you try pinching the return line like it was suggested? And no, that code won't do it - that's the post-cat O2 sensor which has nothing to do with fueling.
Gotta calm down man - freaking out in your posts tends to annoy people and just turns them away. Have you been researching fueling/starting problems in general? Or just waiting on feedback here? A lot of information is out there (like what a post-cat O2 sensor does) that applies to all vehicles including the 1.8T you drive.
