2001 a4b5
Old Sep 6, 2018 | 06:19 PM
Sean McGrath's Avatar
Default 2001 a4b5
My 2001 a4 started knocking on the top end of the motor but only at a stopped idle and starting throwing these codes
P0171
P0011
One was for my can sensor and one sAys bank one is too lean,
Old Sep 7, 2018 | 03:29 PM
A4TurboGuy's Avatar
Clear the codes, see if they come back. if they do, check timing.
Old Sep 18, 2018 | 08:08 PM
John_E's Avatar
Clean your mass air flow sensor and check your fuel trim numbers using a VCDS (VAG-COM). You may have an unmetered air leak or a bad MAFS (been there ... done that with my 2001 Passat).
One.Eight T
Dec 28, 2016 08:22 AM
iaflyer
Oct 14, 2015 04:17 PM
whann79
Sep 16, 2013 10:14 PM
pharriso
Feb 19, 2013 02:16 PM
jreynolds0108
Apr 9, 2011 04:37 PM
