2001 Audi A4 Tiptronic Quirks
I am not as informed about the tiptronic tranny as most, but I have noticed something odd. When I hit the gas in automatic (mode), I notice it shifts kind of roughly between first and second. If I hover around 1,500 RPM, it will continue to upshift and downshift creating a jerking motion. This doesn't happen all the time (about 55 to 60 percent of the time). I have also noticed that when it shifts from third to fourth gear, it also kind of "slams" into place. You can sometimes hear it (faintly) and it is not as smooth as other gear transistions. The second problem arose after I changed the tranny oil using BlauParts equipment. Am I overreacting or does it need more tranny oil, etc.?
you need to refill the tranny while it is at a specific temp monitored by a vag.
You need more fluid is my guess. Did you also change the filter?
Might also want to remove the TCU and make sure there is no water around it.
twinblowersonice
Jan 17, 2008 02:22 AM
ChrisHyde
Sep 28, 2006 11:43 PM
