2001 S4 Driveshaft Center Carrier Bearing
Old Jan 31, 2011 | 05:08 PM
ozzydog's Avatar
Default 2001 S4 Driveshaft Center Carrier Bearing
Can this be replaced without replacing the entire driveshaft. Audi apparently does not sell the part separately. Any hints would be appreciated...thanks
Old Jan 31, 2011 | 06:24 PM
Mike-2ptzero's Avatar
Here you go.
http://www.034motorsport.com/chassis...s-p-13696.html
I can also sell you that part.
Old Jan 31, 2011 | 07:30 PM
CCA4's Avatar
Old Feb 1, 2011 | 09:10 PM
StormUnite's Avatar
how much do u get for it mike?
Old Feb 2, 2011 | 11:08 AM
Around the same price, I am a 034 dealer.
Old Mar 22, 2012 | 08:57 PM
socals4driver's Avatar
Default Center Drive Shaft Bearing
Just ordered one of these from 034
has anyone removed the old one and installed the new one?
Any DIY on it? Any tips would be appreciated before I tackle this at home
Thanks Mason
Old Sep 30, 2014 | 04:14 PM
DelgadoAarron's Avatar
Default 034 center support
i replaced my old one with a 034 one and now after 3 months I'm back at it again. its an oem and poorly made by audi. its supposed to be a vibration dampener. the rubber material is rated only for stock horse power. 034 owns the rights to it and continue to sell the same oem one. it would be better to save your money and buy a one piece propeller shaft (drive shaft). the drive shaft shop at driveshaftshop dot com makes one. 034 also has one but no info on what its rated at for hp support. i personally haven't tried one yet from either of them but I'm looking into saving my pennies and buy a one piece since i am a stage 3 at 520hp. if you find another place that can make a custom one balanced and fits let me know. ill keep looking for other solutions. hope this helps others answer there questions regarding the center support ( dampener bearing support )
Old Sep 30, 2014 | 04:37 PM
Mad Cow's Avatar
Thanks Mason
You're best off bringing it to a driveshaft shop and letting them do it, if you don't have experience in this sort of thing you should leave it to the pros. Plus they can also balance it for you.
redmond1501
Nov 25, 2012 08:47 PM
Mark C
Oct 19, 2012 11:35 PM
Fox Lee
Sep 9, 2012 08:27 PM
mrocke440
Jun 12, 2009 05:51 PM
Mixmastermike
Jan 13, 2008 08:14 PM
