3 little questions
Old Nov 5, 2010 | 06:02 PM
sa9023's Avatar
Default 3 little questions
1. Is it normal for fuel mileage to drop slightly in the winter? I'm assuming so cause of the colder temps, meaning you run slightly more rich
2. If the pulley on my power steering pump is wobbling slightly, does that mean the bearings are about to be shot/I'm going to have to replace the pump soon?
3. How tight is your timing belt/drive belt supposed to be?
Thanks and I apologize in advance for being dumb
Old Nov 5, 2010 | 07:02 PM
gutter's Avatar
1. Yes.
2. Yes.
3. There should be minimal play in the timing belt (approx. 1/8 inch MAX)
Old Nov 5, 2010 | 07:40 PM
a4audia4's Avatar
3. I don't know about the 1.8s but for the 2.8: you should be able hold the timing belt (half way between the right cam pulley and the tensioner) and twist 90 degrees.
Old Nov 5, 2010 | 08:29 PM
jdahlen24's Avatar
Yep, my 2.8L gets about 26 MPG in the summer, but in the winter I get about 16 mpg tooling around town.
I live in Minnesota. The Winters are brutal here, but oh-so-fun putting the Quattro to full use after a big snow!
Old Nov 6, 2010 | 01:20 AM
sa9023's Avatar
Looks like I'm doing a power steering pump replacement soon, ugh...Along with the timing belt, depending on how it feels.
mblayton
Jan 7, 2010 07:35 PM
playboy00786
May 31, 2008 06:37 PM
zchb9
May 20, 2006 01:29 PM
portwolf
May 18, 2006 03:27 PM
VolcanicBlackA4
May 18, 2006 02:11 PM
