30 valve 2.8 ac compressor delete
Old Dec 9, 2008 | 11:07 PM
mike711's Avatar
Default 30 valve 2.8 ac compressor delete
Any 2.8 gurus know if you can bypass a bad ac compressor with a shorter serpentine belt? an maybe what length belt?
thanks
mike
Old Dec 9, 2008 | 11:17 PM
ImTheDevil's Avatar
If nothing else, you could pull the compressor, take some measurements, and make a bracket to mount the AC compressor pulley on a shaft and bearing that will just spin freely. Measure right and you can position the pulley right where it would be on the compressor, and then you don't have to worry about the different belt or any other belt routing issues that may arise as a result of simply deleting it. I honestly doubt it would be that hard to do if you have the compressor in hand to make your measurements.
Old Dec 9, 2008 | 11:33 PM
somebody5788's Avatar
Did the compressor seaze? if not why would you want to take it out of the belt loop a lot of work for nothing... If its seazed you could attempt to replace the bearing on the pully I have seen it done on other cars before. Or just buy a junk yard one can't be very expensive. Ill bet cheaper then eliminating it.
Old Dec 11, 2008 | 12:26 AM
mike711's Avatar
Well I just finished doing the ac compressor delete( just for the winter cold in new hampshire)it is very easy you dont even have to put it in the SERVICE POSITION!. just take the old belt off( loosening the tensioner 17mm socket crank clockwise) and buy a Dayco 69.5 inch serpentine belt, got mine at advanced auto parts $26.50 . reroute the belt around staying short of the compressor, its a alittle tight in there but its very do able.Also noticed a little more throttle response as well
Cheers
Mike
Old Dec 11, 2008 | 02:02 AM
ghost6303's Avatar
if the compressor clutch is disengaged, meaning the AC isnt on, that would essentialy be the same thing as just leaving it alone. theres still the pully, theres still the rotational mass.
Old Dec 11, 2008 | 03:26 AM
anmagro's Avatar
Hmm, considering its only hot half the time here on longisland, and i dont remember the last time i used the AC rather than popin the windows, maby ill do this! lol
Old Dec 11, 2008 | 09:44 AM
shady927's Avatar
how exactly does a car go into the service position? I usually just park it and do what I gotta do to it.
Old Dec 11, 2008 | 11:26 AM
... this is just so not worth it.... it doesn't even take .5 hp to turn that pulley on the compressor. I understand if your compressor is seized and you just don't wanna replace it but deleting it for hp is 100% useless. You would get more power from doing a tune up. The only time the compressor is putting real resistance on the engine is when the AC is on. Sometimes when the front defrost is on i think.
Old Dec 11, 2008 | 11:35 AM
mike711's Avatar
I didn't bypass the ac compressor because I wanted to ,I don't have the time right now to put it in the service position,drain all the old r134 put in a new accumulator etc and wait till the new compressor arrives and install it . I need my car everyday due to my job. All in all the power gain is very minimal but the throttle is a little more responsive.
Old Dec 11, 2008 | 01:25 PM
I was talking more to anmagro. In his case its not worth it at all! Specially if his AC works well. I also have hard time believing noticeable throttle response.
