96 A4 2.8 auto: won't start (no spark) after trans change
Old Apr 2, 2014 | 04:15 PM
  #31
Nico&Gonzo's Avatar
Thanks for the fast reply!
No codes from the VAG.
I changed the fuel filter yesterday, still a no go.
Will check injectors and all what you've mentioned today and will let you know how it goes.
is it normal for the fuel light to stay on when I turn the key? I have all this lights on the dash on, when I put the keys on: engine, temperature, oil and fuel
it can't be the timing cause It turned on monday afternoon, and I also drove it a lil bit. That was the last time it turned on.
Could it be the temperature sensor?
Thanks for the help!
Old Apr 2, 2014 | 10:20 PM
  #32
Mark C's Avatar
I would think the tranny is still low on fluid. While filling it you have to run it thru all the gears, which means it needs to be up on jack stands, or a frame jack with all 4 wheels hanging, so the wheels can actually turn.
The DRn tranny was used from 3/97 to 8/99 on 30V 2.8L cars. It's a 4.111:1 final drive ratio transmission which is the same ratio as a CJP, some of the intermediate gear ratios inside the two transmissions are different though. This is a table of the features of the 2 transmissions. Not all the columns will line up correctly but you should get the idea of whats the same and whats different. I've attached a jpeg of the info as well.
Gearbox Code letters CJP DRN
Intermediate drive -VA No. of teeth Input gear 29 29
Output gear 34 35
Ratio 1.172 1.207
Final drive -VA No. of teeth Pinion shaft 11 11
Crown wheel 30 30
Ratio 2.727 2.727
Intermediate drive -HA No. of teeth Input gear 40 41
Output gear 31 33
Ratio 0.775 0.805
Final drive -HA No. of teeth Pinion shaft 9 9
Crown wheel 37 37
Ratio 4.111 4.111
CAN bus without CAN bus with CAN bus
Electronic throttle without electronic throttle without electronic throttle
Hydraulic control E 17 E 17
Automatic gearbox 01V.1 01V.3
Production from 10.95 3.97
to 8.99
torque converter Code letters K28 F31
Allocation Model Audi A4 1995 ä Audi A4 1995 ä
all markets USA
Engine 2.8 l 2V - 128 kW 2.8 l 5V - 142 kW
Ratios 1st gear 3.665 3.665
2nd gear 1.999 1.999
3rd gear 1.407 1.407
4th gear 1 1
5th gear 0.742 0.742
Reverse gear 4.096 4.096
Attached Thumbnails 96 A4 2.8 auto: won't start (no spark) after trans change-audi-automatic-transmission-differential-table.jpg
Old Apr 3, 2014 | 03:10 AM
  #33
Nico&Gonzo's Avatar
ok, So I've checked: spark, ok. Fuel pump, ok. fuel injector rail, ok.
Also a friend sprayed starter fluid and it starts and stalls. He says it's the Fuel Pump that doesn't have enough power to deliver the fuel... But I've checked the fuel valve (don't know how it's called), the one that has a bolt on it that you open to see if fuel is passing by, and It's coming out of there with pressure (sorry about my english, not my first language). The guy that tested with the scanner said that no codes were showing.
the fuel pump cost about $280... so I want to be sure it's that before make the investment. Any ideas???
Thanks a lot for the help!
Old Apr 4, 2014 | 06:39 PM
  #34
Mark C's Avatar
Change your temperature sensor, its only 15 bucks and has caused more than one car including mine to not start, or run very rough at idle should you be able to get it started, and it leaves no code for the failure. Make sure you get an OEM one not an aftermarket one. If you can get it to start by holding the gas pedal to the floor, or while pumping the gas while cranking then it is most likely your coolant temperature sensor.
2003audiA4avant
Jul 13, 2012 09:32 PM
motorwerks1
Jul 3, 2009 05:35 PM
transit360
Feb 13, 2009 08:35 AM
mat.martins
May 15, 2006 04:01 PM
WeinerSchneitzel
Jan 5, 2006 06:56 AM
