96 a4 cel on rough idle
Old Oct 31, 2009 | 03:35 PM
Michaelp's Avatar
Default 96 a4 cel on rough idle
I have a 96 a4 2.8 with 154,000 on it. The car runs really well unless I let it idle for an extended period of time(like 4-5 min). If I do let it idle to long the cel will come on and throw 0174, 0171,1101, and 1106. I can erase the codes and the cel will stay off until I let it idle for 4-5 min. When I let it idle for that couple of minutes the idle becomes erratic, jumping up and down 200 or so rpm. Most recently the cel also threw 0161, and 0173 codes. I have replaced the MAF and a few vacuum lines and cannot find a vacuum leak anywhere. Any help would be greatly appreciated.
Old Oct 31, 2009 | 03:41 PM
Andrew149's Avatar
those codes dont exsist on this site weird http://wiki.ross-tech.com/index.php/Main_Page
Old Oct 31, 2009 | 03:46 PM
ghost6303's Avatar
well those are P codes, not VAG codes. probably why they are not there.
P0174 System Too Lean (Bank 2)
P0171 System Too Lean (Bank 1)
P1101 - MAF Sensor Out Of Self Test Range
P1106 O2 Sensor Circ.,Bank2-Sensor1 Voltage too Low/Air Leak
replace your MAF and the drivers side primary O2 sensor and you are good to go.
Old Oct 31, 2009 | 03:51 PM
Andrew149's Avatar
ghost how did you find that out?? where'd you go man
Old Oct 31, 2009 | 04:24 PM
dragonrage's Avatar
Google codes. P codes are pretty much standard.
Clean the MAF first. Use MAF cleaner. If not, replace the MAF. Don't touch the O2 sensor until you have your MAF working because a bad MAF sensor can make it appear like the O2 sensors are bad when they may not be. Clear the codes after trying each thing and wait to see if they come back before moving on.
Old Oct 31, 2009 | 07:05 PM
Andrew149's Avatar
i couldnt find what your talking about dragon can i have link
Old Nov 1, 2009 | 01:21 AM
dragonrage's Avatar
http://www.google.com/search?client=...utf-8&oe=utf-8
etc.
It should be obvious that they were P codes IMO.
Old Nov 1, 2009 | 02:06 AM
Andrew149's Avatar
i always used wiki i didnt think those codes would apply to other cars
Old Nov 1, 2009 | 10:57 AM
Midniteoyl's Avatar
As for the codes.. MAF and O2 problems can cause codes for the other. The cheapest to change is the O2 and clean the MAF, but you've already did the MAF.
Does this happen only when idling longer than 3-4 mins? Can you drive all day, sit at a light for 1-2 minutes and not have it happen? I'm thinking more like an engine temp sensor, inlet air temp sensor, etc...
Old Nov 1, 2009 | 12:07 PM
ghost6303's Avatar
the P1011 might cause the P1016 but not the other way around.
you dont happen to have a K&N air filter do you?
