97 1.8t Trans issues (video)
Old Apr 26, 2011 | 08:58 PM
slimty360's Avatar
Default 97 1.8t Trans issues (video)
Im hoping this isnt something big, It makes this almost idk grinding noise when its in ALL gears 1-5 when I accelerate the noise comes, push the clutch in, goes away. I know the clutch is about 30k miles old put in last year but it drives perfectly fine, clutch engauges like always, smooth shifts. Just this damn noise please help.
btw at the end of the video I cut off because someone called me, I said when I push the clutch in the noise goes away,
Thanks!!!
http://s3.photobucket.com/albums/y83...10421-1811.mp4
Old Apr 28, 2011 | 12:01 PM
Mike-2ptzero's Avatar
do you hear the noise when you rev the motor with the car not in gear and not pushing the pedal in?
Old Apr 28, 2011 | 07:53 PM
slimty360's Avatar
Nope, say im at a stop light, trans is in nuetral not touching the clutch pedal just the break and rev it a little bit and its quiet. But when its in gear it happens. When i go to shift between gears and hit the clutch it goes away. I have never got my trans flushed and was meaning to do it when it got warmer out and the noise started.
Old Apr 28, 2011 | 08:22 PM
Sounds transmission related. I would start by changing out the gear oil. If that doesn't help then there might be a bearing going bad.
Old Apr 28, 2011 | 08:25 PM
slimty360's Avatar
Im doing the fluid this weekend and go from there. Could it possibly be the throw-out bearing?
Old Apr 28, 2011 | 08:30 PM
Usually when it is the TOB it makes the noise when you push on the pedal and you can also feel some pulsing in the pedal.
BrendanL'homme
Nov 10, 2013 08:31 PM
jcorkin
Dec 22, 2012 10:04 PM
tofast2belast
Sep 19, 2012 06:08 PM
AnderbrA
May 25, 2012 10:48 PM
